69 Barracuda Vinyl top molding question.
#1216537
04/15/12 09:44 PM
04/15/12 09:44 PM
Posts: 1,093 It's beer:30 somewhere
adventurer
I am working on a 69 Mod Top Barracuda for a freind of mine and have run into a problem. They had the car painted and a new vinyl top put on, I am trying to put the car back together for them. I didn't take the car apart and the car went threw several body shops so pieces are missing and such, but my question is on the vinyl top molding at the bottom of the vinyl top. There is a 2 piece molding that goes from quarter window to quarter window around underneath the back glass, on the last 2 molding attaching clips at each quarter windows is there some other way these are fastened other than with the clip that uses the nut on the back side, because I cannot get to the back side of these last two clips on either side. I took out the back seat and side panels trying to get to them still no access. Also the clips that fasten the rest of the molding in these last two postion the stud part on the clips that I'm using is too long and is hitting the bracing inside the car, so even if I could get to them to put a nut on them I couldn't use it because the stud is hitting. So are there different clips for the last two attaching points at the quarter windows, or do I just need really long skinny arms to some how get up in there? Thanks in advance for any and all replys. ![](/ubbthreads/images/graemlins/beer.gif)
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
Re: 69 Barracuda Vinyl top molding question.
[Re: adventurer]
#1216539
04/18/12 02:24 AM
04/18/12 02:24 AM
Posts: 1,187 USA
big-block-dave
USA
I'll try to look in a car in the next couple of days. Is that MODTOP car in Julie's registry/website?????? http://mooresmopars.com/modregistry.htmlI'm car #29 survivor.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: big-block-dave]
#1216540
04/19/12 11:26 PM
04/19/12 11:26 PM
Posts: 1,187 USA
big-block-dave
USA
Larry, this is how it goes. There are 5 molding clips on the quarter panel. The first 4 from the side window back are a fine threaded screw with a big philips head and NO nut on the inside. This thread is finer than the screws/clips with the nuts on the inside. Now that i think about it, maybe the head has the taper so the molding just snaps over the screw head? I see no type of clip under the screw head. Dave
#1216546
04/19/12 11:43 PM
04/19/12 11:43 PM
Posts: 1,187 USA
big-block-dave
USA
Next 5, let me know how you make out.
