Re: How to wire in a toggle switch for lock up
[Re: 71Polara383]
#1216356
04/15/12 07:58 PM
04/15/12 07:58 PM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
Is it an over drive trans also? electronic lock up and over drive in a A500 trans Yes But can't think of just electronic lock up
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#1216357
04/15/12 09:06 PM
04/15/12 09:06 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Its prolly a A998 trans, those used automatic lockups and cannot be 'wired for on/off'.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#1216358
04/16/12 02:11 AM
04/16/12 02:11 AM
Posts: 1,143 Rockford,IL
71Polara383
Rockford,IL
Not an overdrive. it has a plug in for a lockup at the back of the trans.
[Re: 71Polara383]
#1216359
04/16/12 11:05 AM
04/16/12 11:05 AM
Posts: 1,515 AZ
Mike P
AZ
I haven't done a lockup 904, but I have done a few other lockup convertor retrofits. Basically all you need to do is determine the wire that's the 12V source that locks up the convertor.
Personally I normally wire mine thru a relay and cruise control switch on the brake pedal. I activate it thru a momentary on/off pushbutton switch on the dash. That way it deactivates when the brake pedal is pushed.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: Mike P]
#1216360
04/16/12 01:24 PM
04/16/12 01:24 PM
DARTH V8Я
Its a TRAP!
Never seen a 904 w/ electronic lockup. Interesting...
[Re: DARTH V8Я]
#1216361
04/16/12 03:15 PM
04/16/12 03:15 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
IIRC it's a hydraulic apply with electric release?
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#1216362
04/16/12 05:13 PM
04/16/12 05:13 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yep, all 3-speeds had hydraulic lockup but some 904's from the mid eighties-on had electic release.
[Re: 71Polara383]
#1216364
04/16/12 10:34 PM
04/16/12 10:34 PM
DARTH V8Я
Its a TRAP!
I would imagine it wouldn't unlock the converter and the 904 will go into meltdown.
