How to wire in a toggle switch for lock up #1216353
04/15/12 05:22 PM
04/15/12 05:22 PM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
I got a trans for my 85 Ramcharger today. Its a 904 out of a van but it has an electronic lock up and mine did not. Ive been told i can wire in a toggle switch to lock the torque converter. Is this true? Easy job? Can it hurt anything? How would i go about doing it? Please help moparts!!!!!
Re: How to wire in a toggle switch for lock up [Re: 71Polara383] #1216354
04/15/12 07:01 PM
04/15/12 07:01 PM
Rockford,IL
Rockford,IL
bump. Find it hard to believe no one wants to help me out with this
Re: How to wire in a toggle switch for lock up [Re: 71Polara383] #1216355
04/15/12 07:53 PM
04/15/12 07:53 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
less than 2 hours on a sunday. give em a few before you git yer panties in a bunch....
Re: How to wire in a toggle switch for lock up [Re: 71Polara383] #1216356
04/15/12 07:58 PM
04/15/12 07:58 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Is it an over drive trans also?
electronic lock up and over drive in a A500 trans Yes
But can't think of just electronic lock up
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: How to wire in a toggle switch for lock up [Re: moparts] #1216357
04/15/12 09:06 PM
04/15/12 09:06 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Its prolly a A998 trans, those used automatic lockups and cannot be 'wired for on/off'.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: How to wire in a toggle switch for lock up [Re: DARTH V8Я] #1216358
04/16/12 02:11 AM
04/16/12 02:11 AM
Rockford,IL
Rockford,IL
Not an overdrive. it has a plug in for a lockup at the back of the trans.
Re: How to wire in a toggle switch for lock up [Re: 71Polara383] #1216359
04/16/12 11:05 AM
04/16/12 11:05 AM
AZ
Mike P Online content
Mike P  Online Content
AZ
I haven't done a lockup 904, but I have done a few other lockup convertor retrofits. Basically all you need to do is determine the wire that's the 12V source that locks up the convertor.
Personally I normally wire mine thru a relay and cruise control switch on the brake pedal. I activate it thru a momentary on/off pushbutton switch on the dash. That way it deactivates when the brake pedal is pushed.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: How to wire in a toggle switch for lock up [Re: Mike P] #1216360
04/16/12 01:24 PM
04/16/12 01:24 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Never seen a 904 w/ electronic lockup. Interesting...
Re: How to wire in a toggle switch for lock up [Re: DARTH V8Я] #1216361
04/16/12 03:15 PM
04/16/12 03:15 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
IIRC it's a hydraulic apply with electric release?
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: How to wire in a toggle switch for lock up [Re: Fury Fan] #1216362
04/16/12 05:13 PM
04/16/12 05:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, all 3-speeds had hydraulic lockup but some 904's from the mid eighties-on had electic release.
Re: How to wire in a toggle switch for lock up [Re: John_Kunkel] #1216363
04/16/12 09:11 PM
04/16/12 09:11 PM
Rockford,IL
Rockford,IL
So will it cause any damage to the trans if I do not hook it up?
Re: How to wire in a toggle switch for lock up [Re: 71Polara383] #1216364
04/16/12 10:34 PM
04/16/12 10:34 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
I would imagine it wouldn't unlock the converter and the 904 will go into meltdown.
Re: How to wire in a toggle switch for lock up [Re: DARTH V8Я] #1216365
04/17/12 02:27 AM
04/17/12 02:27 AM
Rockford,IL
Rockford,IL
I dont understand.
Re: How to wire in a toggle switch for lock up [Re: 71Polara383] #1216366
09/24/12 10:04 AM
09/24/12 10:04 AM
Rockford,IL
Rockford,IL
So i have to tackle this so I can use the Ramcharger as mywinter beater. Will this cause damage to this 904? I need this truck to be a dependable driver.
Re: How to wire in a toggle switch for lock up [Re: 71Polara383] #1216367
09/24/12 11:27 AM
09/24/12 11:27 AM
Weatherford Texas
Greg Ducato Offline
Greg Ducato  Offline
Weatherford Texas
Leaving it unlocked will not hurt the trans, you can go the super simple route by running 12 volt to that plug via a toggle switch. Not the best method but certainly functional enough for a beater if you care to use the lockup option.
Re: How to wire in a toggle switch for lock up [Re: 71Polara383] #1216368
09/24/12 12:13 PM
09/24/12 12:13 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
It shouldn't, but not having lock-up will cost you fuel mileage in top gear.
It's worth your time to go by the very good wiring diagram above and get it to work.
Mo' Farts
Moderated by "tbagger".
