65 Coronet K-member change #1215653
04/14/12 01:02 PM
04/14/12 01:02 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
If I change to a 66 K-member in my 65, will that reposition the engine and trans forward or back? How will that affect my driveshaft length and trans mount? I have heard it will move everything forward and I have heard it will move it back.
Re: 65 Coronet K-member change [Re: elmor] #1215654
04/14/12 01:05 PM
04/14/12 01:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It moves it rearward 1 5/8 " according to a thread that was asking this in the race section a week or 2 ago , you'll have to modify the trans mount and shorten the driveshaft and your exhaust .
Re: 65 Coronet K-member change [Re: JohnRR] #1215655
04/14/12 01:13 PM
04/14/12 01:13 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Would a driveshaft from a 66 B-body be the right length or is that just wishful thinking?
Re: 65 Coronet K-member change [Re: elmor] #1215656
04/14/12 02:16 PM
04/14/12 02:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no idea
Re: 65 Coronet K-member change [Re: elmor] #1215657
04/14/12 02:17 PM
04/14/12 02:17 PM
AndyF Offline
AndyF  Offline
Will a '66 driveshaft work with your transmission?
Re: 65 Coronet K-member change [Re: AndyF] #1215658
04/14/12 09:29 PM
04/14/12 09:29 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
I have a mid 70's trans.
Re: 65 Coronet K-member change [Re: elmor] #1215659
04/14/12 11:01 PM
04/14/12 11:01 PM
texas,usa
jld440 Offline
jld440  Offline
texas,usa
Hi my brother changed his 65 b-body k-member and found that you can use a cross member out of a 66-70 b-body four speed car even though it has a 727 auto. everything will line up. He had his drive shaft that came out of the 65 plymouth and it fit back in the car.
1965 plynouth
440/727 10.70 on motor and 9.60 w/150 shot n.o.s
Re: 65 Coronet K-member change [Re: jld440] #1215660
04/14/12 11:10 PM
04/14/12 11:10 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We put a late K-frame in our old 64 Plymouth, modified the crossmember by building a new box for a later trans mount, but the original driveshaft didn't fit. Found one at the junkyard that fit after we moved the rear foward an inch by using the rear spring perch holes (another old trick for improving weight transfer...)
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
