Edelbrock retaining clips #1215580
04/14/12 10:38 AM
04/14/12 10:38 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Where do you find those small retaining clips for an Edelbrock carb? I am talking about the ones that would the linkage together at the power valve.
I haven't lost one YET, but almost.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Edelbrock retaining clips [Re: cdstl] #1215581
04/14/12 11:24 AM
04/14/12 11:24 AM
If you mean the real thin circular wire clips that hold the top L bend of the metering rod to the piston, an eddy strip kit or an OE afb/avs
Re: Edelbrock retaining clips [Re: RapidRobert] #1215582
04/14/12 11:33 AM
04/14/12 11:33 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
They are the 3 clips located in the left side of the picture.
Re: Edelbrock retaining clips [Re: cdstl] #1215583
04/14/12 11:41 AM
04/14/12 11:41 AM
Oh those, Yes the rebuild kit will have em. I need a S clip like in the bottom of the pic. Got an extra?
Re: Edelbrock retaining clips [Re: RapidRobert] #1215584
04/14/12 12:30 PM
04/14/12 12:30 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I got nothin', sorry. I was hoping to find these little dudes somewhere before I lost one without having to buy a kit. I haven't checked the hardware stores yet.
Re: Edelbrock retaining clips [Re: RapidRobert] #1215585
04/14/12 03:19 PM
04/14/12 03:19 PM
scratchnfotraction Offline
I have a spare S rod from an old eddie/carter carb,you can have it, shoot me your addy.
Last eddie rebuild kit I got did not have those in it. I need a couple myself. it has never come apart with out them,but I like to have them in case.
You may find some E clips/hairpins at the hardware store or in the eddie catalog
Re: Edelbrock retaining clips [Re: cdstl] #1215586
04/14/12 03:24 PM
04/14/12 03:24 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
That's where I'd start. Don't go to the big box stores, but instead go to Ace or True Value. Ask for help. Those guys are usually very good at what they do. Hillman, or National, witch ever vender they are using carries these, and several other clips.
I have mechanical Aptitude.
I can screw up anything.
Re: Edelbrock retaining clips [Re: RapidRobert] #1215587
04/14/12 03:30 PM
04/14/12 03:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
RR , I should have one , on a parts carb .
Re: Edelbrock retaining clips [Re: JohnRR] #1215588
04/14/12 03:34 PM
04/14/12 03:34 PM
I believe I found one on a parts carb. Thanks guys
