Roller rocker for BigBlock ?? #1215256
04/13/12 12:42 PM
04/13/12 12:42 PM
Denmark
Dart of Denmark Offline OP
Denmark
Re: Roller rocker for BigBlock ?? [Re: Dart of Denmark] #1215257
04/13/12 12:54 PM
04/13/12 12:54 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Thats a lot of cam for budget rockers. If they were bushed steel units, I'd think you would be okay. But those needle bearing aluminum ones leave a lot of margin for error.... error that could cost you a motor? I'm a guy that normally does NOT subscribe to the "more expensive means its better" mindset, but I'm hesitant with these in your situation.
Re: Roller rocker for BigBlock ?? [Re: Dart of Denmark] #1215258
04/13/12 01:32 PM
04/13/12 01:32 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
Junk. I wouldn't buy anything less than Harland Sharps if I were you. I've broke a set of Cranes with my .650 roller. I now run a RAS stainless set.
Re: Roller rocker for BigBlock ?? [Re: 66er] #1215259
04/13/12 02:46 PM
04/13/12 02:46 PM
Denmark
Denmark
Thanks! That confirm my thought's about them!
My heads are indy sr if I go with Harlans Sharp is S70015k best options for me? I want 1.5 ratio.
Re: Roller rocker for BigBlock ?? [Re: Dart of Denmark] #1215260
04/13/12 03:45 PM
04/13/12 03:45 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
The S70015k rockers are what I run with my SRs. They fit really well and no shimming was necessary. Be sure to look the Harland Sharp rockers over very carefully for metal shavings before you install them.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Roller rocker for BigBlock ?? [Re: 1968RR] #1215261
04/13/12 11:01 PM
04/13/12 11:01 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
T&D
Re: Roller rocker for BigBlock ?? [Re: Dart of Denmark] #1215262
04/14/12 01:36 AM
04/14/12 01:36 AM
New York
polyspheric Offline
polyspheric  Offline
New York
That big photograph tells you exactly where they're going to break.
Boffin Emeritus
Re: Roller rocker for BigBlock ?? [Re: steeldust] #1215263
04/14/12 01:40 AM
04/14/12 01:40 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
x2. haven't had any problems with mine.
Re: Roller rocker for BigBlock ?? [Re: rickraw] #1215264
04/14/12 06:59 AM
04/14/12 06:59 AM
gregsdart Offline
gregsdart  Offline
Definitely spend the money here. I would also be looking for steel body's if anybody like T& D makes them. After what I have spent on repairing Jesel stuff, I want to go to the best.
My total lift is .775.
Re: Roller rocker for BigBlock ?? [Re: polyspheric] #1215265
04/14/12 10:15 AM
04/14/12 10:15 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Could you elaborate on that......just curious.
To me, the needlebearings look too narrow to support any real valvespring pressure for long.
Re: Roller rocker for BigBlock ?? [Re: Dean_Kuzluzski] #1215266
04/14/12 11:24 AM
04/14/12 11:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Smaller needles gives you more rollers in the loading
area
Re: Roller rocker for BigBlock ?? [Re: Dean_Kuzluzski] #1215267
04/14/12 01:00 PM
04/14/12 01:00 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
my guess would be where it's relieved for spring clearance
Re: Roller rocker for BigBlock ?? [Re: MR_P_BODY] #1215268
04/14/12 01:24 PM
04/14/12 01:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
area
Not in the case of those junk rockers , did you check the link ?
Re: Roller rocker for BigBlock ?? [Re: jamesc] #1215269
04/14/12 02:57 PM
04/14/12 02:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Yup - the notch where they needed room, top and bottom. All bending stress focuses on changes in shape or direction.
I have to believe that perhaps 50% of the people who make this stuff have no engineering background at all - they just copy someone else's work.
If you need more room, since the strength is already fixed at the cross-section where clearance is needed, the proper method is to remove even more material, and leave the largest possible radius at the transition.
If those were mine, I'd be buzzing away at the cuts with my tiny Dremel, just blending the cuts into the parent casting.
Yes, small needles are better because you get more. Does that seem counter-intuitive? Each needle (assuming equal length) makes only line contact on the shaft and in the rocker, so more = better.
The smaller needles also have lower moment of inertia, so when they stop and change direction (every cycle) they begin rolling properly rather than skate for a millisecond.
The smaller needle also allows the rocker to have more material around the shaft, or a bigger shaft, since the needles are obviously smaller OD by 2 × the difference in needle thickness. It's small but it's in the right direction. Replace 1/8" needles with 1/16", you get 1/8" free room to bulk up another component (or don't, and save weight).
Boffin Emeritus
Re: Roller rocker for BigBlock ?? [Re: polyspheric] #1215270
04/14/12 03:03 PM
04/14/12 03:03 PM
New York
polyspheric Offline
polyspheric  Offline
New York
BTW: those cute 90° angles are proof that this is not an FEA design, and that the "designer" chose the easiest possible solid geometric shapes (like building something using nothing but bricks).
A huge amount of weight can be pared off that rocker with complete safety. Some of it could be done on a mill by mounting all rockers on a shaft and cutting them all at once, then re-position, etc.
I don't think extra RPM is always a goal, but more control with the same springs always is.
Boffin Emeritus
Re: Roller rocker for BigBlock ?? [Re: JohnRR] #1215271
04/14/12 03:04 PM
04/14/12 03:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
area
Nope didnt look
EDIT
I just looked.... I meant dia not those short needles
Re: Roller rocker for BigBlock ?? [Re: MR_P_BODY] #1215272
04/14/12 03:32 PM
04/14/12 03:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
area
Nope didnt look
EDIT
I had a feeling you didn't look , those bearings are scarey , along with the CCJ rockers and their brittle roller shafts breaking ...
The last place to skimp in on rockers .
Re: Roller rocker for BigBlock ?? [Re: JohnRR] #1215273
04/14/12 06:08 PM
04/14/12 06:08 PM
Holly/MI
Holly/MI
area
Nope didnt look
EDIT
Yeah, I meant the width of the needle bearings, side-to-side, NOT diameter.
Re: Roller rocker for BigBlock ?? [Re: Dean_Kuzluzski] #1215274
04/15/12 12:15 AM
04/15/12 12:15 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The mfg. has decided to avoid the mistake made by almost all rocker mfg. (using full complement Torringtons) and instead is using caged bearings.
Positive: it allows him to use softer shafts by running the inner race directly on the shaft (a full complement uses the shaft as a journal surface and it must be like Rockwell 53-33).
The rollers never sweep past their neighbors turning the other way (as do all full complement). This hasn't been a problem TIKO, since the rocker body does not actually rotate, but only oscillates a few degrees, and despite their small diameter the needles don't rotate much either.
Negative: huge reduction in total bearing area.
Boffin Emeritus
Re: Roller rocker for BigBlock ?? [Re: polyspheric] #1215275
04/15/12 10:18 AM
04/15/12 10:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
So now I'm lost , the CCJ rocker actually built something RIGHT ??? I figured that bearing was cheaper than a full caged needle bearing ?
