ebody clutch pedal questions #121466
09/15/08 08:45 PM
09/15/08 08:45 PM
Idaho
boomerodell Offline OP
Idaho
What side of the clutch pedal should the pin for the rod be? on the brake side or out side?
Re: ebody clutch pedal questions [Re: boomerodell] #121467
09/15/08 08:53 PM
09/15/08 08:53 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
Pin for the rod is on the brake side. The pin on the outside is for the neutral safety switch. Hope this helps.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: ebody clutch pedal questions [Re: RTDaddy] #121468
09/15/08 08:59 PM
09/15/08 08:59 PM
Idaho
Idaho
Thanks, it does. Doing an auto to manual conversion and trying to figure this stuff out. However the pedals that I have do not have a stud on the brake side, just the outside towards the top. There is a hole lower on the pedal, is this where the stud should be?
Re: ebody clutch pedal questions [Re: boomerodell] #121469
09/16/08 03:30 AM
09/16/08 03:30 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
The rod goes on the pin facing the brake pedal the other higher pin is for the overcenter spring and the hole in the pedal arm itself, about 1/4", is for the plastic button for the clutch switch. If you can, post a pic of the pedals because in some ways it sounds like you have a set of A-body pedals.
