The rod goes on the pin facing the brake pedal the other higher pin is for the overcenter spring and the hole in the pedal arm itself, about 1/4", is for the plastic button for the clutch switch. If you can, post a pic of the pedals because in some ways it sounds like you have a set of A-body pedals.
