Side view mirror mounting 70 E-body
#1214479
04/11/12 09:56 PM
04/11/12 09:56 PM
Posts: 305 East Tennessee
Burkenator
East Tennessee
Took off my side view mirror to put different mounts and the proper hardware to mount it. Got the mounting kit from Year One. The mounts are to small for the holes in the door. The old mount in the door has some kind of ridge on it to hold it in the door. Did I get the wrong mounts? And how do you get the "ridged" mounts back in the door? Any suggestions would help. New mount is on the right and the old is on the left in the picture. Thanks!
Re: Side view mirror mounting 70 E-body
[Re: Burkenator]
#1214482
04/11/12 10:08 PM
04/11/12 10:08 PM
Posts: 3,281 West Coast, USA
jbc426
West Coast, USA
I had a difficult time with the "replacement" ones I got from a supplier. They spun once installed. I ended up using some nutsert type that grabbed the sheetmetal better. I also put a small dab of loctite red on them before I installed them.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
