Page 1 of 4 1 2 3 4
512 Low Deck Dyno Results #1214340
04/11/12 09:20 PM
04/11/12 09:20 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline OP
P
SouthEast Michigan
We finished up one of my favorite engines, 400 block, 4.25 stroke,Callies billet I-Beam rods,CP Flat top pistons, 13 to one compression, our custom ring pack that we have been using, 440-1 325 Heads,CNC ported by Indy, T@D single shaft rockers 1.6 ratio, single 4500 manifold, Pro systems 1050, our shelf solid roller 279/290 on 112 installed at 108, .471 lobe lift and VP 110 Fuel. What a great bracket engine these make.
Re: 512 Low Deck Dyno Results [Re: PETE@BESTMACHINE] #1214341
04/11/12 09:20 PM
04/11/12 09:20 PM
SouthEast Michigan
P
P
SouthEast Michigan
One More
Re: 512 Low Deck Dyno Results [Re: PETE@BESTMACHINE] #1214342
04/11/12 09:34 PM
04/11/12 09:34 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Love that combination.
Re: 512 Low Deck Dyno Results [Re: jim sciortino] #1214343
04/11/12 09:39 PM
04/11/12 09:39 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Very nice
Re: 512 Low Deck Dyno Results [Re: PETE@BESTMACHINE] #1214344
04/11/12 09:39 PM
04/11/12 09:39 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
very impressive. shouldnt that block be comming apart at that power?
Re: 512 Low Deck Dyno Results [Re: PETE@BESTMACHINE] #1214345
04/11/12 09:47 PM
04/11/12 09:47 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
my 580" motor, with more head and cam and compression did'nt make that much power...thats awesome!
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 512 Low Deck Dyno Results [Re: Old School] #1214346
04/11/12 09:59 PM
04/11/12 09:59 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
They are great combos and take about all the head you can throw at them.
For dual purpose cars I like a little tighter spread and phase it a bit earlier just to get the torque peaks to come in at a more street-friendly RPM without compromising the head flow.
You give up a little power way up top but the torque still stays "Massive"....it's just 'all-in' a bit earlier in the Rev range.
WIZE
In Car:
Re: 512 Low Deck Dyno Results [Re: PETE@BESTMACHINE] #1214347
04/11/12 10:05 PM
04/11/12 10:05 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Very nice!
Re: 512 Low Deck Dyno Results [Re: HardcoreB] #1214348
04/11/12 10:19 PM
04/11/12 10:19 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Pete,
Wow! That's a bunch out of an engine like that. You prefer the 440-1's over the EZ heads? Any reason?
The reason I ask is we have a 512 RB we run on pump, and it is a beast, at least to us anyways as we close in on the 9sec barrier. Just curious if maybe we picked the wrong heads, or its all the porting you did on those. Yours peaks right where we shift now at 6300rpm...Easier on parts and doesn't seem to hurt our ET.
Could that engine be run at that compression on E85?
Re: 512 Low Deck Dyno Results [Re: Dragula] #1214349
04/11/12 10:51 PM
04/11/12 10:51 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Re: 512 Low Deck Dyno Results [Re: earthmover] #1214350
04/12/12 12:23 AM
04/12/12 12:23 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Can't wait to see the track results.
PLEASE give us an update after a few passes.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 512 Low Deck Dyno Results [Re: pittsburghracer] #1214351
04/12/12 01:01 AM
04/12/12 01:01 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
What size headers are you using?
Re: 512 Low Deck Dyno Results [Re: Darryls-Demon] #1214352
04/12/12 08:13 AM
04/12/12 08:13 AM
gregsdart Offline
gregsdart  Offline
Great numbers! How do you think it would do with alky, and a 110 centerline? Mine came in lower (528 cubes though plus the Alky). I had peak torque by 5,000 and shift at 7100.
Re: 512 Low Deck Dyno Results [Re: gregsdart] #1214353
04/12/12 09:26 AM
04/12/12 09:26 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
I should have motor back in the car this weekend possable testing by the 21st-22nd. Thanks Chuck and Pete you guys rock!
I'll be running a set of TTI Blockhuggers.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 512 Low Deck Dyno Results [Re: Savoy1964] #1214354
04/12/12 11:41 AM
04/12/12 11:41 AM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
What main caps are you running in this thing? Girdle?
Re: 512 Low Deck Dyno Results [Re: JackGTX440] #1214355
04/12/12 11:52 AM
04/12/12 11:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
X2 and I'll add , short or tall fill ? ... Assuming it's a stock block.
Re: 512 Low Deck Dyno Results [Re: JohnRR] #1214356
04/12/12 11:57 AM
04/12/12 11:57 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Block is filled not sure how much and they are 4 bolt mains I'll let Chuck or Pete tell for sure.
Re: 512 Low Deck Dyno Results [Re: Savoy1964] #1214357
04/12/12 12:36 PM
04/12/12 12:36 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
What's the bob weight? Those can be pretty light.
Yeah, it's got a smallblock.
Re: 512 Low Deck Dyno Results [Re: PETE@BESTMACHINE] #1214358
04/12/12 01:38 PM
04/12/12 01:38 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
One More
Pete
What size are the headers in this picture? Are they Hookers? How long is your collector and size please. trying to compare to what I already have.
thnaks
Old Geezer Racing
Re: 512 Low Deck Dyno Results [Re: SCATPACK 1] #1214359
04/12/12 08:41 PM
04/12/12 08:41 PM
Casper, WY
W
Wax Offline
Wax  Offline
W
Casper, WY
Nice numbers. I currently have a 511 in my 3000# Duster. The best I have run with it is 10.00 @ 135.26 mph. That was at 6100' corrected elevation.
My set up is: 4.25 crank, 6.535 length rods, dome pistons that make 14.3 compression ratio, 440-1's touched up by Dwayne Porter(no porting), ProSystems carb(90p90s jets), timing set at 36*, 2" Hooker fender well headers, 1.6 Indy rockers, Comp cams roller cam .631/.631 272 in/280ex @.050 lobe lift .421 installed @ 106. The total lift is .672. I would love to get mine on a dyno to see what it actual makes for power.
Maybe I am missing something. Any suggestions appreciated.
Wax
Page 1 of 4 1 2 3 4
