512 Low Deck Dyno Results
#1214340
04/11/12 09:20 PM
04/11/12 09:20 PM
Posts: 399 SouthEast Michigan
PETE@BESTMACHINE
SouthEast Michigan
We finished up one of my favorite engines, 400 block, 4.25 stroke,Callies billet I-Beam rods,CP Flat top pistons, 13 to one compression, our custom ring pack that we have been using, 440-1 325 Heads,CNC ported by Indy, T@D single shaft rockers 1.6 ratio, single 4500 manifold, Pro systems 1050, our shelf solid roller 279/290 on 112 installed at 108, .471 lobe lift and VP 110 Fuel. What a great bracket engine these make.
Re: 512 Low Deck Dyno Results
[Re: PETE@BESTMACHINE]
#1214344
04/11/12 09:39 PM
04/11/12 09:39 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
very impressive. shouldnt that block be comming apart at that power?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Old School]
#1214346
04/11/12 09:59 PM
04/11/12 09:59 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
They are great combos and take about all the head you can throw at them. For dual purpose cars I like a little tighter spread and phase it a bit earlier just to get the torque peaks to come in at a more street-friendly RPM without compromising the head flow. You give up a little power way up top but the torque still stays "Massive"....it's just 'all-in' a bit earlier in the Rev range.
[Re: HardcoreB]
#1214348
04/11/12 10:19 PM
04/11/12 10:19 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
Pete,
Wow! That's a bunch out of an engine like that. You prefer the 440-1's over the EZ heads? Any reason?
The reason I ask is we have a 512 RB we run on pump, and it is a beast, at least to us anyways as we close in on the 9sec barrier. Just curious if maybe we picked the wrong heads, or its all the porting you did on those. Yours peaks right where we shift now at 6300rpm...Easier on parts and doesn't seem to hurt our ET.
Could that engine be run at that compression on E85?
[Re: Dragula]
#1214349
04/11/12 10:51 PM
04/11/12 10:51 PM
Posts: 2,449 nc
earthmover
nc
[Re: earthmover]
#1214350
04/12/12 12:23 AM
04/12/12 12:23 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Can't wait to see the track results. PLEASE give us an update after a few passes.
[Re: gregsdart]
#1214353
04/12/12 09:26 AM
04/12/12 09:26 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
I should have motor back in the car this weekend possable testing by the 21st-22nd. Thanks Chuck and Pete you guys rock!
I'll be running a set of TTI Blockhuggers.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: JackGTX440]
#1214355
04/12/12 11:52 AM
04/12/12 11:52 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
What main caps are you running in this thing? Girdle?
X2 and I'll add , short or tall fill ? ... Assuming it's a stock block.
[Re: JohnRR]
#1214356
04/12/12 11:57 AM
04/12/12 11:57 AM
Savoy1964
Casco, MI
Block is filled not sure how much and they are 4 bolt mains I'll let Chuck or Pete tell for sure.
[Re: Savoy1964]
#1214357
04/12/12 12:36 PM
04/12/12 12:36 PM
Posts: 1,532 off the grid
340B5
off the grid
What's the bob weight? Those can be pretty light.
Yeah, it's got a smallblock.
[Re: SCATPACK 1]
#1214359
04/12/12 08:41 PM
04/12/12 08:41 PM
Posts: 183 Casper, WY
Wax
Casper, WY
Nice numbers. I currently have a 511 in my 3000# Duster. The best I have run with it is 10.00 @ 135.26 mph. That was at 6100' corrected elevation.
My set up is: 4.25 crank, 6.535 length rods, dome pistons that make 14.3 compression ratio, 440-1's touched up by Dwayne Porter(no porting), ProSystems carb(90p90s jets), timing set at 36*, 2" Hooker fender well headers, 1.6 Indy rockers, Comp cams roller cam .631/.631 272 in/280ex @.050 lobe lift .421 installed @ 106. The total lift is .672. I would love to get mine on a dyno to see what it actual makes for power.
Maybe I am missing something. Any suggestions appreciated.
Wax
