ARP Main Studs- Do these look right?
#1214215
04/11/12 04:47 PM
04/11/12 04:47 PM
Posts: 1,240 Saline, MI
efisixpack
Saline, MI
I had an engine builder assemble my long block (440) for me and one of the items installed were ARP main studs. Looking at the studs, none of them protrude past the nut and many of them don't use the last thread on the nut. Is this normal? Seems like the stud should protrude well past the nut. I have attached a few pictures, hopefully they work. I'd really appreciate your thoughts on this. Thanks!
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
Re: ARP Main Studs- Do these look right?
[Re: efisixpack]
#1214218
04/11/12 04:51 PM
04/11/12 04:51 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
mine stick out some but i think you could back the stud out 2 threads to ingage the nut all the way.
[Re: efisixpack]
#1214219
04/11/12 04:52 PM
04/11/12 04:52 PM
Posts: 1,051 The Great White North
RAMM
They don't usually look like that IME. Maybe the wrong stud kit was used? J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: efisixpack]
#1214221
04/11/12 05:10 PM
04/11/12 05:10 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
That is NOT normal for a set of ARP studs for Mopar. I havent ever seen a set that doesnt extend pass the nuts. That being said, you could do as told, and back out the threads from the block, but I'd pull one and measure the length. Not sure what is going on there. What was the part number of the stud kit?
4 bolt main SBC kits often ( and have for way too long) come with the four outer bolts too short. I back them out until the threads protrude above the head of the nuts. They have never fixed the problem,. just keep sending them wrong.
Its not the end of the World, but they should have been right. I'd like to see what length they measure. Also, this must be an older set of studs, as anything thats newer has had the braoched allen hex in them anyhow.
RIP Monte Smith
[Re: TrWaters]
#1214224
04/11/12 06:05 PM
04/11/12 06:05 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Not sure, but I think your engine builder may have went "budget" on you to save a few bucks, or just used what he had laying around. My ARP main stud kit in my 400 block protruded slightly through the nut, and I also had the issue with them protruding too much at the rear main. If I remember correctly, I clearanced the oilpan slightly to get mine to work.... and the nuts are most definately 12-pt in an ARP kit.
[Re: TrWaters]
#1214226
04/11/12 07:04 PM
04/11/12 07:04 PM
efisixpack
Saline, MI
Thanks guys! According to my receipt, its the 140-5401 kit. Does that look correct? I did notice one of the nuts is a full 2 thread down so it looks like they are all going to have to be reset higher. Additionally, I talked to ARP tech and they said the mains have to be re-torqued to the same spec the shop did them at the first time. Now the confusion is that ARP recommends torquing them to 110 (mains) and my build sheet states they only torqued them to 100. So I assume I just use 100lbs?
I have other issues too with the motor and will likely have a couple more post topics to address them. I do appreciate all of your help and advice.
[Re: efisixpack]
#1214227
04/11/12 07:37 PM
04/11/12 07:37 PM
Posts: 5,875 communist bloc of new jersey
jamesc
was it align bored and/or honed? if so than the normal practice would be to torque them to the spec the machine work was done at. if it wasn't machined i would use the ARP spec. as for the thread engagement i don't particularity care to see anything less than full engagement nor do i like the idea of backing them out. the only one i ever had length problems with was a megablock. i measured what i felt the stud length should be and called ARP. they swore the hemi kit was the correct one for that block...yea right. they were short and i ended up ordering loose studs at the length i measured and they fit perfectly. i told them they needed to use the lengths i ordered and make a new PN for that but they never did.
in all honesty if you wanted to you could probably pull the threads out of the block with the amount of nut engagement you have there but i still don't like it.
[Re: efisixpack]
#1214228
04/11/12 07:37 PM
04/11/12 07:37 PM
CompWedgeEngines
Syracuse,NY
Tr...I think you may have some "NOS" stock there...lol...sounds like an old set as well. They were all marked ARP however.The exception would be if they had them custom made for some reason, but not if it was a listed ARP set as was noted here already. To the OP,ARP has/had changed the torque specs many times over on these studs. If they were an old set anyhow, then 100# would be correct.They have changed the tensile ratings on these over the last 5 or so years. Also, if the builder used standard ARP lube, and not the new ARP Ultra Lube, then it would be 110#. My guess is he went with 100#. They do NOT , appear to me, to be a new set, but could be a unused set he had laying around for a few years? More questions than answers on this one. I would be a bit leary of what else may have gone on there... ![](/ubbthreads/images/graemlins/shruggy.gif)
RIP Monte Smith
[Re: jamesc]
#1214230
04/11/12 08:09 PM
04/11/12 08:09 PM
efisixpack
Saline, MI
Good tips. I'm going to send some pictures yo ARP tomorrow and see if they are just and old (but new)pieced together set. Having both hex and 12-point nuts seems odd to me too.
Unfortunately this is just he tip of the iceberg. After pulling off their own timing cover I found that is was making contact with the chain (made by them too). Not a big deal as I found it before it was run. Also, the cam timing was set at 114 when I asked for 112 (again not a major issue) BUT I did notice there were A LOT of small chips already coming off the bronze gear and it was so tight in there it took both a screwdriver to unscrew it off the cam along with a lot of force from underneath using the handle end of another screwdriver. I n addition they cut my intake (fine) but there are a bunch of aluminum shavings in the lifter galley.
I pretty bummed right now because I know I'm going to have to take this thing all the way back down and pay more to have it checked out. Hopefully the shop will step up and fix the issues. They are considered a reputable shop and this motor could just be a fluke.
Again, I appreciate the input, I want to get all the info I can before I contact the shop so I don't make anything a bigger issue than it needs to be.
I need a beer....
[Re: efisixpack]
#1214231
04/11/12 08:14 PM
04/11/12 08:14 PM
efisixpack
Saline, MI
I forgot to mention the new timing chain has 9/16" slop in it. My old chain had less. Is they way too much for a new chain. Obviously I'm a little rusty with engine building but trying to catch back up.
[Re: efisixpack]
#1214233
04/11/12 08:33 PM
04/11/12 08:33 PM
jamesc
if by some chance they align bored it and didn't use an undersized chain that could be the problem.
as for your being rusty i hate to say it but sounds like the last guy to have his hands in it wasn't very shiny. i know it's a drag but finding problems like you are sounds like you need to start over because you just don't know what else is going on. i'd be wanting to measure everything and look it over.
[Re: jamesc]
#1214234
04/11/12 09:50 PM
04/11/12 09:50 PM
CompWedgeEngines
Syracuse,NY
I agree,,,what he is finding in unacceptable, especially the shavings. It may be a good shop, but they didnt have their " good" guys working on it for sure. Tear it down now, it will be a lot easier than later.
Sorry for your trouble.
RIP Monte Smith
