Re: HEMI superstock engine specs
[Re: Moparnut426]
#1213519
04/10/12 07:41 PM
04/10/12 07:41 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
WOW, does anyone in here have any tear down pictures of them? Im sure the pistons have a really short skirt to save weight somewhat. The rest is probly very foreign compared to standard hemi parts.
cam bearing changed to 60mm . lifter bores all relocated most are wider betrween each other and angles changed
for starters a standard proceedure the block is decked. as much as 3/8" is removed. pistons and rods can be far from factory
here's the cam
home of the Sox and Martin Hemi Duster
[Re: SSDAcuda]
#1213523
04/10/12 10:01 PM
04/10/12 10:01 PM
HEMIFRED
SOUTH JERSEY
from above Quote:
The big end of rods are only Honda 1.88" but the overall weight is same as stock
[Re: HEMIFRED]
#1213524
04/10/12 11:27 PM
04/10/12 11:27 PM
Posts: 3,504 DFW
mr_340
DFW
(426 Hemi) OE 6.861" length, 842 grams minimum OE Rod Journal - 2.375 Rod Housing - 2.500 OE Main Journal - 2.750 Main Housing - 2.943
SS rods can weigh 833g. Doug Fazzolare told me they aren't running the Honda rod journal rods. I don't know if the big dogs are running them. 1000 HP through a small rod journal seems like a high stress (rear journal).
Floyd Lippencott IV
