how big of an exhaust #1212531
04/09/12 08:57 AM
04/09/12 08:57 AM
plainwell,michigan
1fastaspen Offline OP
plainwell,michigan
I have tti 2in primary with a 3 1/2in collectr and a 3in exhaust should i leave it at the 3in or go to a 3 1/2 it it really worth the trouble and extra money thanks for the help henry
75 duster 440 in the works
71 pro street cuda
Re: how big of an exhaust [Re: 1fastaspen] #1212532
04/09/12 09:41 AM
04/09/12 09:41 AM
an8sec70cuda Offline
How much motor and what kind of mufflers are you using now?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: how big of an exhaust [Re: 1fastaspen] #1212533
04/09/12 10:11 AM
04/09/12 10:11 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I would say no...
3" should do just fine...
after saying that...on mine, since I have no exhaust yet...Im going 3 1/2" because I'm tapping into the collector...fender exit wells with 3 1/2" collectors that will have caps...
Re: how big of an exhaust [Re: smokinwoody] #1212534
04/09/12 10:31 AM
04/09/12 10:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use 2" TTI headers with a 3-1/2" collector. I went with 3" and the X-pipe setup out to my rear bumber and I love it. Dont know if it slows it down any from open headers as I have never uncapped it. But I just wanted to have a pump gas car that I can drive to the track and run 10's through the pipes which it does. Good luck , Ron
Re: how big of an exhaust [Re: 1fastaspen] #1212535
04/09/12 10:35 AM
04/09/12 10:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
before I did that I'd just slap a pair of cut outs on it. Even if you don't go biggger you'll have an idea if it will help. Uncap then and run it. If you drop some et (which you will) then you have to decide if it's worth the cost. I have mine back not far from the muffler so they don't hang to low.
Coming soon!!!!
Re: how big of an exhaust [Re: 1fastaspen] #1212536
04/09/12 11:00 AM
04/09/12 11:00 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Well from what I remember you dropped the mufflers and gained .2 ET. I always tried to get the orig owner to put a better muffler on that car. Currently, I think they are some modified 'turbo' design? If nothing else some bullets in the same 3" should pick it up.
Re: how big of an exhaust [Re: 1fastaspen] #1212537
04/09/12 11:36 AM
04/09/12 11:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think you would be wasting your money... if you
have a good flowing muffler you can stay with the
3"... remember the farther back the exhaust is, the
cooler it is and the cooler exhaust has less area
in it(less area/volume, not sound volume) also the
farther back the muffler is, the easier it is to
control the note(DB level).... I went with 3 1/2"
collectors to 3" to the back bumper
Re: how big of an exhaust [Re: MR_P_BODY] #1212538
04/09/12 11:51 AM
04/09/12 11:51 AM
plainwell,michigan
plainwell,michigan
Right now it has a cheap sonic turbo muffler and an h pipe to the rear axle so maybe a dyno max muffler and an x pipe would be just fine and it did pick up 2 tenths with open headers.how about a 3" pipe with a 3 1/2" muffler wonder how that would work
71 pro street cuda
Re: how big of an exhaust [Re: 1fastaspen] #1212539
04/09/12 12:11 PM
04/09/12 12:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The inlet and outlet of the muffler has NO bearing
on how it flows... volume of the muffler does along
with the construction of the interior... if you notice
that alot of mufflers have a 3 1/2" inlet but its necked
down to 3"... it does zero change
Re: how big of an exhaust [Re: 1fastaspen] #1212540
04/09/12 12:31 PM
04/09/12 12:31 PM
I had a 440 1969 Dart that picked up .8 and 9 MPH by removing a set of 2.5 turbo muffs and sides pipes exiting in front of the rear wheels, I used a set of 14x7x3.0 inch oval Magna flow with three inch pipes from the 3.5 inch Hookerfender well headers on my pump gas Duster. The muffs. are mounted behind the rear end between the rear sub frames and outer 1/4 panels, it is nice to drive and only looses .04 ET and .15 MPH in he 1/8 mile when I've removed the complete exhaust sytem at the local track, probally the weight making the differences and not the flow restrictions, not worth removing for that little gain The Duster runs low tens(best of 9.993 at 134.5 MPH ) on pump gas, motor only with the air cleaner and exhaust on 3450 lbs with me in it
Re: how big of an exhaust [Re: Cab_Burge] #1212541
04/09/12 10:04 PM
04/09/12 10:04 PM
plainwell,michigan
plainwell,michigan
Well then a 3" system with an x pipe and a good mufflers is the way to go thanks for all help guys
71 pro street cuda
Re: how big of an exhaust [Re: 1fastaspen] #1212542
04/09/12 10:26 PM
04/09/12 10:26 PM
so ca
mikesiron Offline
mikesiron  Offline
so ca
3 OR 3 1/2 but I would use spin tech mufflers. THE BEST FOR SOUND AND POWER. http://www.spintechmufflers.com/ After you here them you will never want any other muffler!!!
Re: how big of an exhaust [Re: mikesiron] #1212543
04/09/12 10:57 PM
04/09/12 10:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What a person likes their car to sound like is a very
personal thing... what size engine also changes the
sound of the muffler .... I quit telling people what
to buy because my taste may be very different than
theirs... I happen to like them on the quieter size
when cruising and dont mind a nice note when I get
on it... I hate the low end rumbling when I'm cruising...
like I said.... its a very personal thing.... and I
spent 30+ years in the exhaust lab at Chrysler
Re: how big of an exhaust [Re: MR_P_BODY] #1212544
04/10/12 09:45 AM
04/10/12 09:45 AM
plainwell,michigan
plainwell,michigan
what spin techs do you use dont want something to loud but would like a deep sound
71 pro street cuda
Re: how big of an exhaust [Re: 1fastaspen] #1212545
04/10/12 09:57 AM
04/10/12 09:57 AM
I'd stay w/ 3" and get a straight through muffler like the dynomax ultraflow, hooker max flow, or magnaflow. You'll see more of a gain from swapoping mufflers than anything else. If you don't have an H or X pipe, get one. An X pipe makes more power, but H pipes sound better..just my personal opinion. I'd stay away from spintech mufflers.
CHIP
Re: how big of an exhaust [Re: an8sec70cuda] #1212546
04/10/12 10:51 PM
04/10/12 10:51 PM
plainwell,michigan
plainwell,michigan
Was also looking at the ultra flows in the 6" round 3"in and out insead of the ovals any difference between them two
71 pro street cuda
Re: how big of an exhaust [Re: 1fastaspen] #1212547
04/10/12 11:02 PM
04/10/12 11:02 PM
so ca
mikesiron Offline
mikesiron  Offline
so ca
I use the 3 1/2 race muffler. At WOT its like you are uncorked!! Maybe not what you want for the street.
Re: how big of an exhaust [Re: mikesiron] #1212548
04/10/12 11:18 PM
04/10/12 11:18 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
all 3.5 tube.. with turn downs at the axle. w/big flowmasters
Re: how big of an exhaust [Re: 70blackfish] #1212549
04/11/12 08:36 AM
04/11/12 08:36 AM
plainwell,michigan
plainwell,michigan
Yes the race mufflers are going to be way to loud i have run them on my cuda before so i think i will go with the round ultr a flows in 3" and dump them at the rear axle and why stay away from the spin techs???
71 pro street cuda
Re: how big of an exhaust [Re: 1fastaspen] #1212550
04/11/12 08:43 AM
04/11/12 08:43 AM
gregsdart Offline
gregsdart  Offline
Put a bung in the exhaust just in front of one of the mufflers and test for back pressure while under full throttle. Might show restrictions if you have any. I don't think the 3 inch pipe is a problem, but the mufflers may be depending on how good they are.
