Re: how big of an exhaust
[Re: 1fastaspen]
#1212532
04/09/12 09:41 AM
04/09/12 09:41 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
How much motor and what kind of mufflers are you using now?
[Re: 1fastaspen]
#1212533
04/09/12 10:11 AM
04/09/12 10:11 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
I would say no...
3" should do just fine...
after saying that...on mine, since I have no exhaust yet...Im going 3 1/2" because I'm tapping into the collector...fender exit wells with 3 1/2" collectors that will have caps...
[Re: 1fastaspen]
#1212537
04/09/12 11:36 AM
04/09/12 11:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have tti 2in primary with a 3 1/2in collectr and a 3in exhaust should i leave it at the 3in or go to a 3 1/2 it it really worth the trouble and extra money thanks for the help henry
I think you would be wasting your money... if you have a good flowing muffler you can stay with the 3"... remember the farther back the exhaust is, the cooler it is and the cooler exhaust has less area in it(less area/volume, not sound volume) also the farther back the muffler is, the easier it is to control the note(DB level).... I went with 3 1/2" collectors to 3" to the back bumper
[Re: MR_P_BODY]
#1212538
04/09/12 11:51 AM
04/09/12 11:51 AM
Posts: 257 plainwell,michigan
1fastaspen
plainwell,michigan
Right now it has a cheap sonic turbo muffler and an h pipe to the rear axle so maybe a dyno max muffler and an x pipe would be just fine and it did pick up 2 tenths with open headers.how about a 3" pipe with a 3 1/2" muffler wonder how that would work
75 duster 440 in the works
71 pro street cuda
[Re: 1fastaspen]
#1212539
04/09/12 12:11 PM
04/09/12 12:11 PM
MR_P_BODY
The inlet and outlet of the muffler has NO bearing on how it flows... volume of the muffler does along with the construction of the interior... if you notice that alot of mufflers have a 3 1/2" inlet but its necked down to 3"... it does zero change
[Re: 1fastaspen]
#1212540
04/09/12 12:31 PM
04/09/12 12:31 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I had a 440 1969 Dart that picked up .8 and 9 MPH by removing a set of 2.5 turbo muffs and sides pipes exiting in front of the rear wheels, I used a set of 14x7x3.0 inch oval Magna flow with three inch pipes from the 3.5 inch Hookerfender well headers on my pump gas Duster. The muffs. are mounted behind the rear end between the rear sub frames and outer 1/4 panels, it is nice to drive and only looses .04 ET and .15 MPH in he 1/8 mile when I've removed the complete exhaust sytem at the local track, probally the weight making the differences and not the flow restrictions, not worth removing for that little gain The Duster runs low tens(best of 9.993 at 134.5 MPH ) on pump gas, motor only with the air cleaner and exhaust on 3450 lbs with me in it
[Re: Cab_Burge]
#1212541
04/09/12 10:04 PM
04/09/12 10:04 PM
1fastaspen
plainwell,michigan
Well then a 3" system with an x pipe and a good mufflers is the way to go thanks for all help guys
71 pro street cuda
[Re: mikesiron]
#1212543
04/09/12 10:57 PM
04/09/12 10:57 PM
MR_P_BODY
3 OR 3 1/2 but I would use spin tech mufflers. THE BEST FOR SOUND AND POWER. http://www.spintechmufflers.com/ After you here them you will never want any other muffler!!!
What a person likes their car to sound like is a very personal thing... what size engine also changes the sound of the muffler .... I quit telling people what to buy because my taste may be very different than theirs... I happen to like them on the quieter size when cruising and dont mind a nice note when I get on it... I hate the low end rumbling when I'm cruising... like I said.... its a very personal thing.... and I spent 30+ years in the exhaust lab at Chrysler
[Re: MR_P_BODY]
#1212544
04/10/12 09:45 AM
04/10/12 09:45 AM
1fastaspen
plainwell,michigan
what spin techs do you use dont want something to loud but would like a deep sound
71 pro street cuda
[Re: 1fastaspen]
#1212545
04/10/12 09:57 AM
04/10/12 09:57 AM
an8sec70cuda
I'd stay w/ 3" and get a straight through muffler like the dynomax ultraflow, hooker max flow, or magnaflow. You'll see more of a gain from swapoping mufflers than anything else. If you don't have an H or X pipe, get one. An X pipe makes more power, but H pipes sound better..just my personal opinion. I'd stay away from spintech mufflers.
[Re: an8sec70cuda]
#1212546
04/10/12 10:51 PM
04/10/12 10:51 PM
1fastaspen
plainwell,michigan
Was also looking at the ultra flows in the 6" round 3"in and out insead of the ovals any difference between them two
71 pro street cuda
[Re: 70blackfish]
#1212549
04/11/12 08:36 AM
04/11/12 08:36 AM
1fastaspen
plainwell,michigan
Yes the race mufflers are going to be way to loud i have run them on my cuda before so i think i will go with the round ultr a flows in 3" and dump them at the rear axle and why stay away from the spin techs???
71 pro street cuda
[Re: 1fastaspen]
#1212550
04/11/12 08:43 AM
04/11/12 08:43 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Put a bung in the exhaust just in front of one of the mufflers and test for back pressure while under full throttle. Might show restrictions if you have any. I don't think the 3 inch pipe is a problem, but the mufflers may be depending on how good they are.
