Ignition misfire related to charge issue?
#1212295
04/08/12 12:31 PM
04/08/12 12:31 PM
Posts: 804 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
Trying to work all the bugs out of my newly installed 408. In addition to the charge issue I also have a misfire (pops out the exhaust and breaks up) once the motor gets to approx 5K rpms. I was wondering if I am not getting enough voltage to the orange box if that could be a cause of the misfire?
Working through the weekend so trying to get ideas to start trouble shooting. Timing, fuel pressure under load(I have 9 lbs at the rail per the gauge at idle), igition are all on the list to check but was thinking that the two problems maybe related. Also going to poke around with the volt meter.
1972 Road Runner
1988 Shelby CSX-T
Re: Ignition misfire related to charge issue?
[Re: Dunnuck Racing]
#1212298
04/08/12 03:52 PM
04/08/12 03:52 PM
racerx20
Standard but OK
Standard but OK
Houston, Texas
Using a mopar performance electronic dis and a Pertronix coil. Thanks for the info, time to do some checking.
1972 Road Runner
1988 Shelby CSX-T
[Re: racerx20]
#1212299
04/08/12 04:33 PM
04/08/12 04:33 PM
RapidRobert
I'd check plugs/wires/rotor phasing/timing
[Re: MoparforLife]
#1212301
04/10/12 09:30 PM
04/10/12 09:30 PM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
Is it a newer orange box? It sounds a lot like how my old orange box died. It started missing in the upper RPM range and eventually flat out died.
[Re: racerx20]
#1212303
04/11/12 10:41 AM
04/11/12 10:41 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have seen the stock wiring give guys headaches just like this. Try a separate circuit for the ignition system. Run nothing through the original harness and see what happens. Then try the box, then rotor , plugs, wires. start with a plug gap of .035.
