Ignition misfire related to charge issue? #1212295
04/08/12 12:31 PM
04/08/12 12:31 PM
Houston, Texas
racerx20 Offline OP
Standard but OK
racerx20  Offline OP
Standard but OK
Houston, Texas
Trying to work all the bugs out of my newly installed 408. In addition to the charge issue I also have a misfire (pops out the exhaust and breaks up) once the motor gets to approx 5K rpms. I was wondering if I am not getting enough voltage to the orange box if that could be a cause of the misfire?
Working through the weekend so trying to get ideas to start trouble shooting. Timing, fuel pressure under load(I have 9 lbs at the rail per the gauge at idle), igition are all on the list to check but was thinking that the two problems maybe related. Also going to poke around with the volt meter.
1972 Road Runner
1988 Shelby CSX-T
Re: Ignition misfire related to charge issue? [Re: racerx20] #1212296
04/08/12 12:52 PM
04/08/12 12:52 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i wouldn't think so especially if your batery is up to snuff. keep working on the ign and issues
Re: Ignition misfire related to charge issue? [Re: mikemee1331] #1212297
04/08/12 01:32 PM
04/08/12 01:32 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Once you get down to around 8 volts to the ignition,the Mopar boxes will misfire. It also depends on which coil and distributor you use with it.
Re: Ignition misfire related to charge issue? [Re: Dunnuck Racing] #1212298
04/08/12 03:52 PM
04/08/12 03:52 PM
Houston, Texas
racerx20 Offline OP
Standard but OK
racerx20  Offline OP
Standard but OK
Houston, Texas
Using a mopar performance electronic dis and a Pertronix coil. Thanks for the info, time to do some checking.
1972 Road Runner
1988 Shelby CSX-T
Re: Ignition misfire related to charge issue? [Re: racerx20] #1212299
04/08/12 04:33 PM
04/08/12 04:33 PM
I'd check plugs/wires/rotor phasing/timing
Re: Ignition misfire related to charge issue? [Re: RapidRobert] #1212300
04/08/12 05:04 PM
04/08/12 05:04 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yes it could very easily be because of a faulty charging system not keeping a good charge in the battery. Seen it many times.It doesn't take long for it to show upon the high end. especially if you are running electric accessories like fans and fuel pump.
Re: Ignition misfire related to charge issue? [Re: MoparforLife] #1212301
04/10/12 09:30 PM
04/10/12 09:30 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Is it a newer orange box? It sounds a lot like how my old orange box died. It started missing in the upper RPM range and eventually flat out died.
Re: Ignition misfire related to charge issue? [Re: MarkZ] #1212302
04/11/12 12:11 AM
04/11/12 12:11 AM
Houston, Texas
racerx20 Offline OP
Standard but OK
racerx20  Offline OP
Standard but OK
Houston, Texas
It's at least 8 years old it has been on the car since I've owned it. I have a spare I will throw it on and see if there is any change. Just waiting for my dual field alternator that maybe part of the issue.
1972 Road Runner
1988 Shelby CSX-T
Re: Ignition misfire related to charge issue? [Re: racerx20] #1212303
04/11/12 10:41 AM
04/11/12 10:41 AM
gregsdart Offline
gregsdart  Offline
I have seen the stock wiring give guys headaches just like this. Try a separate circuit for the ignition system. Run nothing through the original harness and see what happens. Then try the box, then rotor , plugs, wires. start with a plug gap of .035.
