Page 1 of 5 1 2 3 4 5
what's wrong... #1211804
04/07/12 06:13 PM
04/07/12 06:13 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
drove to the track, great. Car felt good, then this be? http://www.youtube.com/watch?v=p93jNXMKFWA&feature=youtu.
Seems to pull hard until 5800-6k then breaks up. Fuel pressure is fine, plugs look good, it just starts dropping cylinders. Take a look alisten. Swapped the Orange box out, did a little better but still started farting at the top end. everything is new excep the coil (blaster II 15 years old) any ideas? All in all we had fun, Chris (440pursuit) ran his new Demon back-2-back-2-back 11.05's. Drove home all good..
Coming soon!!!!
Re: what's wrong... [Re: Mr.Yuck] #1211805
04/07/12 06:14 PM
04/07/12 06:14 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I had a similar problem and it turned out to be a faulty connector on the coil.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: what's wrong... [Re: Mr.Yuck] #1211806
04/07/12 06:43 PM
04/07/12 06:43 PM
Guitar Jones Online laugh2
Hmm, how old are your valve springs?
Re: what's wrong... [Re: Mr.Yuck] #1211807
04/07/12 06:46 PM
04/07/12 06:46 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
sounds like fuel starvation to me. Nothing in first gear then all through the second half of the track. What kind of fuel pump?
Re: what's wrong... [Re: dc426] #1211808
04/07/12 06:50 PM
04/07/12 06:50 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Hmm, how old are your valve springs? Less than 2 years and 350 miles
Chris it's a holley blue pump, ran it last year no issues, holds 6.25lbs (ca adjust for more) all the way down the track. Air was real good today...
Re: what's wrong... [Re: Mr.Yuck] #1211809
04/07/12 07:09 PM
04/07/12 07:09 PM
Tampa Florida
dc426 Offline
dc426  Offline
Tampa Florida
I'd try another pump. I run 2 blue pumps for good measure. Should be running 7-8 pounds pressure.
Re: what's wrong... [Re: Mr.Yuck] #1211810
04/07/12 07:11 PM
04/07/12 07:11 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Please tell me you have a steel billet brum in your 727. Does not look like you are letting the car move far enough forward after you are cleaning out the motor. Ask Chip what can happen by doing that.
Re: what's wrong... [Re: Mr.Yuck] #1211811
04/07/12 07:12 PM
04/07/12 07:12 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
have you checked that your carb opens all the way?
if the carb opens fully,(check by having someone flooring the loudpedal with engine turned of and look down into the carb to make sure,or put your hand on the throttlearm on the carb while someone holds the pedal down to make sure you get an actual fully open carb) otherways check for electrical faults or valvesprings.
Re: what's wrong... [Re: 1Fast340] #1211812
04/07/12 08:45 PM
04/07/12 08:45 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
carbs are the same as last year, evrything is except I put in a new steering column.
Did the same thing I always do in the box, burn out, roll forward clean the plugs back in 1 and move into the beams.
I'll try bumping the pressure to 7. Had it this way last year w/ no issues, wonder if the 14mph head wind had anything to do w/ it...
Re: what's wrong... [Re: Mr.Yuck] #1211813
04/07/12 10:01 PM
04/07/12 10:01 PM
Tampa Florida
dc426 Offline
dc426  Offline
Tampa Florida
change the fuel pump! Then put a good ignition in it.
Re: what's wrong... [Re: dc426] #1211814
04/07/12 10:13 PM
04/07/12 10:13 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I have an MSD new in the box on the shelf. It will be going in soon...and I'll bump the pressure up... Just wondering why it didn't do this last year. Mayeb I'll get the Holley Black. Thanks..
Re: what's wrong... [Re: Mr.Yuck] #1211815
04/07/12 10:24 PM
04/07/12 10:24 PM
Tampa Florida
dc426 Offline
dc426  Offline
Tampa Florida
Probably from sitting around all winter. Sometimes they just go. Does Chris have a pump you can try?
Re: what's wrong... [Re: dc426] #1211816
04/07/12 10:55 PM
04/07/12 10:55 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I'm sure he does, thing is we had a mild winter, probably drove it twice a month or more... It does sound louder, if that's possible. Would the pressure still be decent if the pump was going bad? It held a steady 6-6.25 all the way down track
Re: what's wrong... [Re: Mr.Yuck] #1211817
04/07/12 11:15 PM
04/07/12 11:15 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Man your are asking for trouble.. staging like that.. you need to put that car in 1st gear and let it move forward a least 2-3 foot.. Not sure why you rev it up like that/clean it out ? is something wrong with it ? Not a good thing to do..you have some bad habits there..we have a ford guy that does that..we all pick on him and laugh at him. if you have to do it there is something wrong with the car..trust me it don't sound cool..
Re: what's wrong... [Re: VernMotor] #1211818
04/07/12 11:29 PM
04/07/12 11:29 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
how is the voltage?
Re: what's wrong... [Re: Mr.Yuck] #1211819
04/07/12 11:36 PM
04/07/12 11:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Down time on the fuel system is worse on it than
running is.... things do go bad
Re: what's wrong... [Re: VernMotor] #1211820
04/07/12 11:42 PM
04/07/12 11:42 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
vern it roll at least 5-10' after clearing. They don't give us much room that's for sure. Usually I just take it up to about 3k hold or a second and move forward...seemd like it wanted to stall so I gunned it more than usual.
Still have the factory amp gauge hooked up, looks good.
Re: what's wrong... [Re: Mr.Yuck] #1211821
04/07/12 11:52 PM
04/07/12 11:52 PM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Sounds like good advice.
1. Check all connectors and voltages.
2. Like Duane Says- Your'e blowing the candles out" with the Creamsicle box. Get the MSD on with legit voltage.
3. Fuel pressure weak now, too. I have a pump, but Crank yours up and watch gauge thru run. You need 8-10psi.
4. We'll check the adjustment on the carbs. I'll give you the Dominator and and Weiand mini tunnel. You'll really need to get gas there, then!
5. Raise antenna's on Gazoo's Helmet!
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: what's wrong... [Re: 440PURSUIT] #1211822
04/07/12 11:54 PM
04/07/12 11:54 PM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
That's right Yeah Cher!
Re: what's wrong... [Re: Mr.Yuck] #1211823
04/07/12 11:55 PM
04/07/12 11:55 PM
iowa
rook440 Offline
rook440  Offline
iowa
Check your grounds too to make sure they are clean and now corosion ,,,a good ground is very important and is often over looked ...
