High heat painting question. #1210736
04/06/12 12:21 AM
04/06/12 12:21 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I am getting a new exhaust system custom made and will have most of the system ceramic coated black but there is a heat sheild that sits about 1 inch away from the muffler and i wanted to color it a dark blue to match my car. The powder coaterer said they is no way to either powder coat or paint it and not have the applied coating color bubble up.
Anyone find anything in a custom color coating that they can think of that would hold up to high heat like that??
Stu
Re: High heat painting question. [Re: MidPenMopar] #1210737
04/06/12 01:16 AM
04/06/12 01:16 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Re: High heat painting question. [Re: Jeremiah] #1210738
04/06/12 01:24 AM
04/06/12 01:24 AM
VHT Flameproof comes in blue:
http://www.vhtpaint.com/products/flameproof/
I saw that but it's all in flat, and you need a way to heat it like a giant oven.
I guess you can not get glossy finish in a high heat paint maybe?
Re: High heat painting question. [Re: MidPenMopar] #1210739
04/06/12 02:36 PM
04/06/12 02:36 PM
Andrewh Offline
Andrewh  Offline
caliper paint seems to come in high gloss and blue. just not sure it will be the same shade. can't imagine that bubbling due to temps.
Re: High heat painting question. [Re: MidPenMopar] #1210740
04/06/12 02:47 PM
04/06/12 02:47 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
How big is the heat shield? I have used VHT on all kinds of stuff (exhaust, manifolds, etc.) and never cured it in an oven. The heat of the application seems to work well if you are comfortable with that. As Andrew said maybe the disc brake paint would better suit your application.
If you were worried about curing it the powder coating place could stick it in the oven.
Re: High heat painting question. [Re: Jeremiah] #1210741
04/06/12 02:55 PM
04/06/12 02:55 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Or let the heat from the exhaust cure it?
**Photobucket sucks**
Re: High heat painting question. [Re: Andrewh] #1210742
04/06/12 07:50 PM
04/06/12 07:50 PM
Say that's a great idea!!
Re: High heat painting question. [Re: MidPenMopar] #1210743
04/06/12 09:31 PM
04/06/12 09:31 PM
Minnesota
peabodyracing Offline
Minnesota
NIC Industries in Oregon, of which Prismatic Powder Coatings is a division, has recently come up with a high temp coating that they claim will stand up to header heat. Comes in a wide range of colors and many samples I'd seen at their booth at a Chicago trade show last fall were higher gloss. You have to be certified by them to apply the stuff. I wanted to pursue the certification for our shop but fortunately for our powder coating business, have been too busy to get away for a couple day training class. Sorry I don't know more about the process involved.
You can contact them to find out if anyone in or near the Bay area has been certified. It would likely be someone who already does powder and/or ceramic coatings. Just do a web search for NIC.
Your powder coater is correct in being concerned; best current high temp powders are good to about 1200 degrees but limited in color options to pretty much flat black and silver. Conventional powder coatings will start to fail after they've seen 400 degrees for any extended period of time. Usually they lose gloss, then adhesion in this situation.
Hope this helps.
Lead, follow or get the hell out of the way
