Re: High heat painting question.
[Re: MidPenMopar]
#1210740
04/06/12 02:47 PM
04/06/12 02:47 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
VHT Flameproof comes in blue:
http://www.vhtpaint.com/products/flameproof/
I saw that but it's all in flat, and you need a way to heat it like a giant oven.
I guess you can not get glossy finish in a high heat paint maybe?
How big is the heat shield? I have used VHT on all kinds of stuff (exhaust, manifolds, etc.) and never cured it in an oven. The heat of the application seems to work well if you are comfortable with that. As Andrew said maybe the disc brake paint would better suit your application.
If you were worried about curing it the powder coating place could stick it in the oven.
[Re: MidPenMopar]
#1210743
04/06/12 09:31 PM
04/06/12 09:31 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
NIC Industries in Oregon, of which Prismatic Powder Coatings is a division, has recently come up with a high temp coating that they claim will stand up to header heat. Comes in a wide range of colors and many samples I'd seen at their booth at a Chicago trade show last fall were higher gloss. You have to be certified by them to apply the stuff. I wanted to pursue the certification for our shop but fortunately for our powder coating business, have been too busy to get away for a couple day training class. Sorry I don't know more about the process involved.
You can contact them to find out if anyone in or near the Bay area has been certified. It would likely be someone who already does powder and/or ceramic coatings. Just do a web search for NIC.
Your powder coater is correct in being concerned; best current high temp powders are good to about 1200 degrees but limited in color options to pretty much flat black and silver. Conventional powder coatings will start to fail after they've seen 400 degrees for any extended period of time. Usually they lose gloss, then adhesion in this situation.
Hope this helps.
Lead, follow or get the hell out of the way
