Replaced My Indy Single Plane....
#1210622
04/05/12 07:16 PM
04/05/12 07:16 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
with an Indy 2D. Man what a different in throttle response and overall crispness! 511 Indy Max Wedge Head (worked over by Compuflow) solid roller with an AED1000 CFM carb. Can't wait to drive it, just need to fix the brakes and get a new throttle bracket. What are you guys with the Indy 2D intake running for a throttle bracket?
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
Re: Replaced My Indy Single Plane....
[Re: 440Jim]
#1210626
04/05/12 09:27 PM
04/05/12 09:27 PM
ChrgrCuda
Texas, USA
Thanks for the replies. Jim - you are right, however I couldn't close the factory hood on my 69 Charger. So I now have the dual plane installed. If anybody needs a hardly used at all powder coated Indy single plane max wedge intake let me know.
[Re: ChrgrCuda]
#1210627
04/05/12 09:56 PM
04/05/12 09:56 PM
Posts: 8,886 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
AED1000 CFM carb
Really !?! I've got a 526 stroker with the MW heads and Indy DP ... I was leaning towards an 850, possibly even with vac secondaries because I thought anything bigger would be unresponsive! How much street driving do you do versus strip? Is that a stick or auto car?
Oh ... I used Andy's brackets - I had to grind either the intake or bracket for the back bolt to fit - I ground the intake.
[Re: Big B]
#1210631
04/06/12 03:36 AM
04/06/12 03:36 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I use the Indy dual plane on my 493. The eng has only been in the car since last summer and the dual plane is the only intake I have tried. But I love it as the car has very nice low end grunt. Its a street/strip car and has run 10.70's so far on pump thru the pipes but I plan to work on some tuning this year and maybe get my hands on a bigger carb to try. I also run a standard Holley 850 DP and was thinking I need more carb as I had to jet it up alot from the old 440 combo I use to run and I mean alot as it wants alot of fuel. But it went faster with more fuel and I am not done yet. I would love to try a Dominator on my 63 with the dual plane and the single plane to see which it likes better. As for my throttle cable I use the Lokar setup and it works great. And it is so simple to set up. You dont need any throttle bracket other then what they give you. It bolts on the back carb stud and the return spring also hooks to it. Works good for me and is very simple. Ron
[Re: BSB67]
#1210633
04/06/12 09:13 AM
04/06/12 09:13 AM
ChrgrCuda
Texas, USA
I drove around without the hood, for a while and it still had a bookoo of torque. I just couldn't shut the hood. Haven't driven it yet with the Indy Dual Plane, just fired it up. This is an 80% street car. My Combo: 1969 Charger '77 440 Block 4.25 Stroke 6.86 Rods w/2.2 journals Reverse Dome Forged Pistons Indy EZ Heads, Max Wedge Ports, Milled and Ported by Compuflow, flow 350 CFM on his bench Comp Solid Roller 250 and 259 @ .050 .649 and .655 lift Harland Sharp Rockers Max Wedge Size Indy 2D 1000 AED DP carb Prepped by AED for my motor CRT 727 w/manual valve body Dr. Diff Dana 60 w/3.73's
[Re: ChrgrCuda]
#1210635
04/06/12 09:34 AM
04/06/12 09:34 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
There's probably 20+ HP in working the Lower plenum to "tweak" the 2 weaker runners on the 2D, the upper plenum runners already flow ~355-360 in MW form. With the radius work the ports will all flow about the same, look up the Roger Helgessen (Dr Air) article. Once you do those tweaks you have a dual plane capable of up to an over 700HP that gives unequalled throttle response and (most importantly) roll-on part-throttle torque that makes a 500" motor ALWAYS feel like 500", from wall to wall off idle to redline. ot knocking the Indy single, it's a great HP maker at WOT, but being a street driven car spends ~90% of it's time below 4K and at part throttle and below 75 mph, the 2D is just an overall more efficient torque builder, especially for a 3500+ pound mostly street car...you'll see I've run the single on a couple 493's, it's more of a 'light switch' , the torque is either 'off' ( yeah, it's good, but by comparison, maybe not as good as it could/should be) or 'on' ( but 'really' on). For the street : I always visualize running the Motor on a road race type powerband, not a drag strip. The 'overall enjoyment regardless of road conditions means more to me than a few extra Hp 'bragging numbers' up top....maybe I'm just getting old. But I'll give up a couple tenths in ET if it would give me back seconds off a lap time....opinions vary I guess.
[Re: Streetwize]
#1210639
04/06/12 01:58 PM
04/06/12 01:58 PM
ChrgrCuda
Texas, USA
Andy
Where did you say I can find your brackets? I have your book as well, helped guide me through my build process. It was a super good read.
