Page 3 of 3 1 2 3
Re: $20 drive shaft loop no drilling required [Re: pacifica] #1210001
01/28/13 01:29 AM
01/28/13 01:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Bolt it onto the crossmember with existing through bolts. Drop back of driveshaft and slide hoop up to bracket and bolt together.
Why do some of you guys insist on making them with such
a long lever arm.... that looks nice but you better
have a plate between it and your butt
Re: $20 drive shaft loop no drilling required [Re: MR_P_BODY] #1210002
01/28/13 01:48 AM
01/28/13 01:48 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Been this way for 20 years
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: $20 drive shaft loop no drilling required [Re: hemi-itis] #1210003
01/28/13 01:58 AM
01/28/13 01:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know if your rolling eyes were directed at me
or not but I even have a problem with yours... you
have what 1 bolt on each side 3/4 of the way out on
those long pieces of flat stock.... put a couple of
good bolts in CLOSE to the loop and cut 3/4 of that
wasted flat stock off
Re: $20 drive shaft loop no drilling required [Re: MR_P_BODY] #1210004
01/28/13 11:41 AM
01/28/13 11:41 AM
hemi-itis Offline
hemi-itis  Offline
No Raff,roll not directed at you.Recentley replaced the old one with a new one and just went into exsisting holes.The old loop was missing the top half and you have to get the whole kit so I just installed it complete.
Guess I could shorten it up a tad
Re: $20 drive shaft loop no drilling required [Re: hemi-itis] #1210005
01/28/13 12:53 PM
01/28/13 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
OK... if you bolt it in close you can cut a good bit
of that flat stock off and have it work better and
look better(I hope you have a top half on the new one)
Re: $20 drive shaft loop no drilling required [Re: MR_P_BODY] #1210006
01/28/13 01:29 PM
01/28/13 01:29 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Here's a $54 one, no drilling required:
http://compare.ebay.com/like/330716703817?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Bolts to the crossmember. I always pass tech. Then again, the tech guy never looks under my car.
Re: $20 drive shaft loop no drilling required [Re: 67Satty] #1210007
01/28/13 02:22 PM
01/28/13 02:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Passing tech and saving your butt are two different
worlds.... I'm sure I could put my rod caps on with
grade 2 bolts... it might live for a few turns but
then again maybe it wouldnt.... I wonder if there
is a reason for good quality bolts
EDIT
But use what ever you want.. its your car and your a$$
Re: $20 drive shaft loop no drilling required [Re: MR_P_BODY] #1210008
01/28/13 02:55 PM
01/28/13 02:55 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nice looking loops you guys built! I'd run either if I needed one.
Don't you like how this board looks at new ideas lol
Re: $20 drive shaft loop no drilling required [Re: FastmOp] #1210009
01/28/13 03:13 PM
01/28/13 03:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry... I look at them from a structural point..
do you think its wise to control a rotating item
thats way out of whack from 12"-14" away or right
next to it... you can use what ever floats your boat
but I was just trying to point out the reason it should
be closer
Re: $20 drive shaft loop no drilling required [Re: FastmOp] #1210010
01/28/13 03:17 PM
01/28/13 03:17 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Satty,
Hold 5lbs in your hand.
Then grab one end of a 2 foot long piece of wood and put the 5 pounds on the other end... A bit harder to hold up.
Nothing wrong with your loops, just the suspended ring and the way it will lever against your attachment points. I'd find a way to solidly mount the ring so there is another attachment point than just the crossmember bolts.
Decent design, just needs some refinements, IMO.
Re: $20 drive shaft loop no drilling required [Re: RobX4406] #1210011
01/28/13 03:22 PM
01/28/13 03:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Satty,
Yep... like putting a bolt through the ring into the
floor pan with a reinforcement inside.... but that
takes drilling
Re: $20 drive shaft loop no drilling required [Re: MR_P_BODY] #1210012
01/28/13 08:20 PM
01/28/13 08:20 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Satty,
takes drilling
As much as I don't want to drill a hole in my floor
I'm afraid I know that in order for the loop to have a chance
at being effective I'm gonna have to plate the floor at the top
like Mr P. says above
My car is street car more than race car but I made more than
90 passes at the track last year [with NO loop] and I think I've
pushed my luck long enough.
Can't wait till this is put away and this
returns
Re: $20 drive shaft loop no drilling required [Re: FastmOp] #1210013
01/28/13 11:34 PM
01/28/13 11:34 PM
Az
Crizila Offline
Crizila  Offline
Az
New ideas don't mean good ideas. Running a lever arm that long to support the loop is a BAD idea. It will just be more shrapnel heading your way with any kind of front yoke /cross failure - and possibly even with a rear failure. Loop support should be in line with the loop and bolted through the floor / frame with at least 4 bolts. JMO. I have experienced shaft failures from both ends. The can be very mild or extremely violent. You gotta build for the latter.
Fastest 300
Re: $20 drive shaft loop no drilling required [Re: Crizila] #1210014
01/29/13 12:20 AM
01/29/13 12:20 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Over the last 40 plus years of racing I have yet to break a front u joint, twisted off drive shafts,never broke a tail shaft , spread rear yokes, blew out lots of rear joints. That $20 dollar universal loop is all you need. NHRA says it must be mounted within 6" of the joint. Keep it centered at 6" from the Joint and the bolts won't catch and tear your stuff.
Re: $20 drive shaft loop no drilling required [Re: rowin4] #1210015
01/29/13 01:09 AM
01/29/13 01:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was gonna let this drop BUT I cant and Steve I'm
suprized you would say its good enough.... if the
front breaks(I've seen a few) and that thing bends
down, it will bend enough to allow the shaft to exit
the loop.... I guess none of you guys ever seen a
car pole vault... all he has to do is bolt the loop
to the floor on that design... that'll make it 100%
better
Page 3 of 3 1 2 3
