$20 drive shaft loop no drilling required
#1209961
04/05/12 12:36 AM
04/05/12 12:36 AM
Posts: 57 CT
440Kilmartin
CT
69 roadrunner 4speed.....20dollar jegs loop.. with some extra bends bolted it to the cross member similar to the high dollar ones out there. Save your money!
Re: $20 drive shaft loop no drilling required
[Re: OUTLAWD]
#1209968
04/05/12 09:12 PM
04/05/12 09:12 PM
Posts: 7,506 Az
Crizila
Az
Wonder if it will pass tech?
Fastest 300
[Re: Kevins493]
#1209970
04/05/12 09:33 PM
04/05/12 09:33 PM
Posts: 1,505 TN
SCATPACK 1
TN
I didn't think it would hold up either. I would like it better if it had a brace to one of the seat bracket bolts
Old Geezer Racing
[Re: rickraw]
#1209974
04/06/12 12:56 AM
04/06/12 12:56 AM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
after studing his pic again, i think the drive shaft bangin around in the hoop would catch the bolts & rip everything out. one way to find out would to try it. hope that wouldn't happen to anyone.
The loop part is a standard design, there are lots of cars driving around with driveshaft loops like that.
If a driveshaft banging around would rip the steel off the crossmember, it would be more likely to rip out the thin metal of the floorboards which is where they are typically attached.
Re: $20 drive shaft loop no drilling required *DELETED*
[Re: 440Kilmartin]
#1209976
04/06/12 02:18 AM
04/06/12 02:18 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
[Re: HPMike]
#1209977
04/06/12 09:59 AM
04/06/12 09:59 AM
Exit1965
Rancho Cordova, CA
A driveshaft let go on one of the FAST RR's a while back. Broke the U joint at the front powershifting 1-2 on a 6"bias ply tire. Even with a properly installed, heavy duty loop(that did its job), it TORE UP the floors and crossmember and broke the transmission output shaft in two and shattered the tailhousing to pieces. You could probably hang 2500 pounds or more off a hardened 833 output shaft and not even bend it let alone break it...
MB
So all that damage happened because of (after) the driveshaft hitting the driveshaft loop? Sounds like the yoke got caught on the bolts inside the loop and torqued everything and broke it. For the driveshaft loop to rip the floor up, something more than a driveshaft rattling around inside it has to happen.
[Re: Exit1965]
#1209978
04/06/12 10:08 AM
04/06/12 10:08 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
[Re: HPMike]
#1209979
04/06/12 11:37 AM
04/06/12 11:37 AM
Exit1965
Rancho Cordova, CA
MB
You missed the point...
The loop didnt rip the floor up because it wasnt attached at the floor. The loop "contained" the shaft. Im sure it violently "danced" around inside the loop, but the shaft never fell. It bent up the the loop terribly, but it didnt break away. It was one of the US CARTOOL ones that bolts to the 4 bolts of the crossmember.
MB
I didn't think your story made any connection between the carnage of the RR you describe, and whether the OPs driveshaft loop will work. Maybe that wasn't your point, even though you said "Even with a properly installed, heavy duty loop" it tore up the floor and crossmember, which certainly sounds like you were suggesting that the strength/design of the driveshaft loop played a large role in the damage to the RR. If not, what was the point, and what does the properly installed, heavy duty driveshaft loop have to do with a torn up RR?
Maybe your main point was that hanging weight off something is not a good test, if so it was only made at the end of your example. Fair enough, but it hardly addresses whether OPs driveshaft loop would work as intended if a driveshaft fell into it.
