440 decode help #120969
09/15/08 01:09 PM
09/15/08 01:09 PM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
Can you guys help me figure my 440 out
I have a 440 build date 1-6-71
only numbers I could find are 2 10 424
basic 440 cast number 2536430-5
D N pointed at the d
on clock type points to the 7 oclock position wtih a smaller dot on on the 11 oclock position
Motor is rebuilt but I am just curious
Thanks for any help
Dean
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: 440 decode help [Re: moepwr] #120970
09/15/08 03:14 PM
09/15/08 03:14 PM
AndyF Offline
AndyF  Offline
Has the ID pad been machined smooth? What about the VIN pad?
Re: 440 decode help [Re: moepwr] #120971
09/15/08 04:16 PM
09/15/08 04:16 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Thanks for any help
Dean
curious about WHAT ??? it's possibly a 71 model year engine if it was ASSEMBLED on the date you say , but I'm guessing that date is the CASTING date on the side of the block ?
Is this number stamped or cast in ? If stamped WHERE is it stamped ?
Re: 440 decode help [Re: JohnRR] #120972
09/16/08 12:33 AM
09/16/08 12:33 AM
OWL
Culvers Offline
Culvers  Offline
OWL
Do you have photos?
Culvers
Re: 440 decode help [Re: Culvers] #120973
09/16/08 02:15 AM
09/16/08 02:15 AM
dogdays Offline
dogdays  Offline
What does the engine ID pad under the distributor have stamped into it? that will tell you the most about the way the engine was built.
R.
Re: 440 decode help [Re: dogdays] #120974
09/17/08 11:21 AM
09/17/08 11:21 AM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
The distributer pad
has H 440
Below it a 804 or 8 4
I am just trying to get as much info as possible about the original motor. I am just curious.
I know the motor is a different motor due to the work done on it. It is bored .30 over balanced and has head work with 915 heads. Crane gold 1.6 roller rockers and a bigger cam. It has a performer RPM intake and holley 750 carb, Electronic ignition. It has TTI exhaust with the H-pipe.
Re: 440 decode help [Re: moepwr] #120975
09/17/08 11:50 AM
09/17/08 11:50 AM
U.S.S.A.
U.S.S.A.
The distributer pad
has H 440
such as ???
Its a std fare NON HP low compression 1972 440 assembled on August 4 1971 , had a forged crank originally, it wasn't installed in any performance model , came out of a C barge.
What else would you like to know ?
Re: 440 decode help [Re: JohnRR] #120976
09/17/08 12:20 PM
09/17/08 12:20 PM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
Thanks John for the information
Re: 440 decode help [Re: moepwr] #120977
09/17/08 12:23 PM
09/17/08 12:23 PM
U.S.S.A.
U.S.S.A.
your welcome .
