Re: 440 decode help
[Re: moepwr]
#120971
09/15/08 04:16 PM
09/15/08 04:16 PM
Posts: 75,036 U.S.S.A.
JohnRR
U.S.S.A.
Can you guys help me figure my 440 out
I have a 440 build date 1-6-71
only numbers I could find are 2 10 424
basic 440 cast number 2536430-5
D N pointed at the d
on clock type points to the 7 oclock position wtih a smaller dot on on the 11 oclock position
Motor is rebuilt but I am just curious
Thanks for any help
Dean
curious about WHAT ??? it's possibly a 71 model year engine if it was ASSEMBLED on the date you say , but I'm guessing that date is the CASTING date on the side of the block ?
Is this number stamped or cast in ? If stamped WHERE is it stamped ?
Re: 440 decode help
[Re: dogdays]
#120974
09/17/08 11:21 AM
09/17/08 11:21 AM
Posts: 776 Penguin Country
moepwr
Penguin Country
The distributer pad
has H 440
Below it a 804 or 8 4
I am just trying to get as much info as possible about the original motor. I am just curious.
I know the motor is a different motor due to the work done on it. It is bored .30 over balanced and has head work with 915 heads. Crane gold 1.6 roller rockers and a bigger cam. It has a performer RPM intake and holley 750 carb, Electronic ignition. It has TTI exhaust with the H-pipe.
Re: 440 decode help
[Re: moepwr]
#120975
09/17/08 11:50 AM
09/17/08 11:50 AM
JohnRR
U.S.S.A.
The distributer pad
has H 440
such as ???
Its a std fare NON HP low compression 1972 440 assembled on August 4 1971 , had a forged crank originally, it wasn't installed in any performance model , came out of a C barge.
What else would you like to know ?
