Ideas for cleaning a K-member #1208561
04/02/12 09:17 PM
04/02/12 09:17 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Whats a good way to clean this piece? I was thinking the local car wash??
Re: Ideas for cleaning a K-member [Re: cudabitten] #1208562
04/02/12 09:22 PM
04/02/12 09:22 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
if you have a place to soak it with degreaser/solvent for a couple of days even if you spray it every few hours or two or three times a day that will help. And when you take it to the car wash make sure the owner has gone home they don't like it when you get their nice clean bays all greasy.....DAMHIK
Re: Ideas for cleaning a K-member [Re: A12] #1208563
04/02/12 09:27 PM
04/02/12 09:27 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I always have mine acid dipped and E-coated!
Admiration For Multiple Carburetor Vehicles...
Re: Ideas for cleaning a K-member [Re: Stewpar] #1208564
04/02/12 09:32 PM
04/02/12 09:32 PM
eastern, pa.
eastern, pa.
What kind of business does that? It might be worth a few bucks to get that done.
Re: Ideas for cleaning a K-member [Re: cudabitten] #1208565
04/02/12 10:10 PM
04/02/12 10:10 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Local machine shop and have it hot tanked. Tim
Re: Ideas for cleaning a K-member [Re: astjp2] #1208566
04/02/12 10:52 PM
04/02/12 10:52 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
That's what I did...see before and after...doesn't get much cleaner than that...and just for the record, I have tried the car wash thing and not even close...just my
before:
Re: Ideas for cleaning a K-member [Re: LYNCHROAD69.5] #1208567
04/02/12 10:52 PM
04/02/12 10:52 PM
Massachusetts
Massachusetts
after
Re: Ideas for cleaning a K-member [Re: LYNCHROAD69.5] #1208568
04/02/12 10:55 PM
04/02/12 10:55 PM
Massachusetts
Massachusetts
Before
Re: Ideas for cleaning a K-member [Re: LYNCHROAD69.5] #1208569
04/02/12 10:57 PM
04/02/12 10:57 PM
Massachusetts
Massachusetts
after (how do people post multiple pictures in one post?)
Re: Ideas for cleaning a K-member [Re: LYNCHROAD69.5] #1208570
04/02/12 11:21 PM
04/02/12 11:21 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
How much to have a K-frame Hot-Tanked?
Re: Ideas for cleaning a K-member [Re: LYNCHROAD69.5] #1208571
04/02/12 11:23 PM
04/02/12 11:23 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
before:
Not even close is right, I wouldn't go to a car wash that took the paint off
Re: Ideas for cleaning a K-member [Re: A12] #1208572
04/02/12 11:25 PM
04/02/12 11:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I guess the question should have been "clean it" or "prep it for paint"
Re: Ideas for cleaning a K-member [Re: A12] #1208573
04/03/12 12:37 AM
04/03/12 12:37 AM
Massachusetts
Massachusetts
$60 for the K-frame.
Re: Ideas for cleaning a K-member [Re: A12] #1208574
04/03/12 12:40 AM
04/03/12 12:40 AM
Massachusetts
Massachusetts
before:
actually, that k-frame had little or no paint on it before it was hot tanked. It was not original to my car.
Re: Ideas for cleaning a K-member [Re: A12] #1208575
04/03/12 12:44 AM
04/03/12 12:44 AM
Massachusetts
Massachusetts
Well put Mike...I would like to retract my previous statements and answer the OP's question..if you want to clean it...car wash. If you want to paint it..hot tank!
Re: Ideas for cleaning a K-member [Re: LYNCHROAD69.5] #1208576
04/03/12 10:50 AM
04/03/12 10:50 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i have media blasted them for customers for around $50. ready for paint when they get them back
Re: Ideas for cleaning a K-member [Re: chrisf] #1208577
04/03/12 11:31 AM
04/03/12 11:31 AM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
Depends what you are doing and your ultimate goals. I initially had mine blasted and then took it to be powder coated. During the baking phase to burn off any contaminants, grease/oil/grime oozed out from the seams. Let it bake for a quite a while and it just kept coming out with no end in sight. Decided just to have it hot tanked which got rid of all the crud inside and out.
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Ideas for cleaning a K-member [Re: LYNCHROAD69.5] #1208578
04/03/12 11:59 AM
04/03/12 11:59 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Having one done now,
estimate is about $125 to chemically dip it and powder coat it
