feeler guage and ring gap #1208366
04/02/12 05:15 PM
04/02/12 05:15 PM
S.E. WI
allmopar Offline OP
allmopar  Offline OP
S.E. WI
I am filing my rings and and checking the gap in the cylinder bore.
What is the proper way to check the ring gap with a feeler guage. Find the right thickness guage that has a smooth fit by itself in the gap or use your finger to gently push the guage into the gap. If you push the guage into the gap with your finger you can get the next thicker size guage to fit into the gap.
Re: feeler guage and ring gap [Re: allmopar] #1208367
04/02/12 05:34 PM
04/02/12 05:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t get all caught up in the resistance it takes and the same w/setting the valves. I go for a fairly snug feel w/out killing my fingers and making the job harder than it needs to be. What`s a .001 diff anyhow.
Re: feeler guage and ring gap [Re: Thumperdart] #1208368
04/02/12 05:38 PM
04/02/12 05:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
... just some drag is all I do
Re: feeler guage and ring gap [Re: Thumperdart] #1208369
04/02/12 05:40 PM
04/02/12 05:40 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
u want the ring about 1" down in the bore with snug feeler fit.
Re: feeler guage and ring gap [Re: MR_P_BODY] #1208370
04/02/12 05:40 PM
04/02/12 05:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I agree with Dom, dont overthink it. Consistency is more important in the way you do it rather than how tight the feeler gauge is.
Re: feeler guage and ring gap [Re: MR_P_BODY] #1208371
04/02/12 05:58 PM
04/02/12 05:58 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
6 people will get 7 differant readings, like they said keep it simple
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: feeler guage and ring gap [Re: 440lebaron] #1208372
04/02/12 09:32 PM
04/02/12 09:32 PM
Az
Crizila Offline
Crizila  Offline
Az
I would suggest investing in a ring squaring tool though - if you want real good consistancy with your measurements.
Fastest 300
Re: feeler guage and ring gap [Re: Crizila] #1208373
04/02/12 10:05 PM
04/02/12 10:05 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Roll of masking tape the size of bore,,minus a small amount, does a good job.
If you like drag racing, support your local track.
Re: feeler guage and ring gap [Re: CHAPPER] #1208374
04/02/12 10:28 PM
04/02/12 10:28 PM
S.E. WI
allmopar Offline OP
allmopar  Offline OP
S.E. WI
Thanks guys for the tips,
Consistancy and medium pressure with the guage.
I am using a piston upside down with a ring in the 2nd groove to push the ring in the cylinder straight.
Re: feeler guage and ring gap [Re: allmopar] #1208375
04/02/12 10:44 PM
04/02/12 10:44 PM
tn
robnbird Offline
robnbird  Offline
tn
YOU CAN HAVE 100% CONFIDENVE IN JUST THE WAY YOU ARE DOING THE JOB.
Re: feeler guage and ring gap [Re: allmopar] #1208376
04/02/12 11:29 PM
04/02/12 11:29 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
That is exactly how I do it. Just use a old stock flat top piston. Stock bore piston still works well, even in a .060" over block.
Brian Dunnigan
Re: feeler guage and ring gap [Re: '72CudaRacer] #1208377
04/02/12 11:57 PM
04/02/12 11:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I bought one of these and really like the way it works. My son Matt was using it tonight fitting the rings for his new engine.
http://www.summitracing.com/parts/SME-906002/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: feeler guage and ring gap [Re: allmopar] #1208378
04/03/12 12:27 AM
04/03/12 12:27 AM
One of the old Mopar Gods told me to MAKE sure the rings where square in the bore and file them tight enough to where the feeler gauge would barely go in, I did that for while when i was racing my M.W. 426 stocker. Now I make sure the piston rings are square in the bore and the feeler gauge, .020 or .021 for the top ring will barely go in without hurting my fingers but the next size bigger won't go in no matter how hard I push on it I have buggered up a buch of rings and cylinder walls over the years by having NOT ENOUGH ring gap .005 to big is way better than .0005 to small when it comes to ring gaps
Re: feeler guage and ring gap [Re: pittsburghracer] #1208379
04/03/12 02:26 AM
04/03/12 02:26 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i have one of those and one of these
http://www.summitracing.com/parts/SME-906000/
they both work well and are pretty nice usa quality. also for deburring the ends of the rings a diamond nail file works nice
Re: feeler guage and ring gap [Re: jamesc] #1208380
04/03/12 10:26 AM
04/03/12 10:26 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
apparently you do want a "snug" fit to know the accurate size of the gap. I always used a "smooth" feel. I can drop the feeler gauge in, it doens't wiggle side to side at all, and I can slide it up and down against the cylinder wall, through the gap, and it "glides" through.
when I talked to the tech guy at KB, he told me that my gaps would actually be a bit bigger than what I was measuring because of how I was measuring.
oh well. too big on ring gaps are better than too small. Plus, I think I've seen some write ups from different builders online who say that they've noticed no loss in Hp with as much as a .060" ring gap
**Photobucket sucks**
Re: feeler guage and ring gap [Re: Cab_Burge] #1208381
04/03/12 11:23 AM
04/03/12 11:23 AM
Az
Crizila Offline
Crizila  Offline
Az
For sure on the last sentence . I use a ring squaring tool made by PRC. I like it cause I can reach through the middle and actually pull the ring up against the tool to make sure it is square to the bore.
Fastest 300
Re: feeler guage and ring gap [Re: 70Cuda383] #1208382
04/03/12 12:41 PM
04/03/12 12:41 PM
hooziewhatsit Offline
With a 4.030" bore, a 0.020" ring gap is ~0.11% of the total circumference. A 0.080" ring gap is ~0.63%.
If that 0.5% difference is enough to kill the overall power... something else is wrong
As long as they're big enough they don't butt together during operation, I'd say you're good to go.
