Re: feeler guage and ring gap
[Re: Thumperdart]
#1208368
04/02/12 05:38 PM
04/02/12 05:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I don`t get all caught up in the resistance it takes and the same w/setting the valves. I go for a fairly snug feel w/out killing my fingers and making the job harder than it needs to be. What`s a .001 diff anyhow.
... just some drag is all I do
[Re: MR_P_BODY]
#1208370
04/02/12 05:40 PM
04/02/12 05:40 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I agree with Dom, dont overthink it. Consistency is more important in the way you do it rather than how tight the feeler gauge is.
[Re: MR_P_BODY]
#1208371
04/02/12 05:58 PM
04/02/12 05:58 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
6 people will get 7 differant readings, like they said keep it simple
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#1208372
04/02/12 09:32 PM
04/02/12 09:32 PM
Posts: 7,506 Az
Crizila
Az
I would suggest investing in a ring squaring tool though - if you want real good consistancy with your measurements.
Fastest 300
[Re: allmopar]
#1208375
04/02/12 10:44 PM
04/02/12 10:44 PM
Posts: 914 tn
robnbird
tn
Thanks guys for the tips, Consistancy and medium pressure with the guage. I am using a piston upside down with a ring in the 2nd groove to push the ring in the cylinder straight.
YOU CAN HAVE 100% CONFIDENVE IN JUST THE WAY YOU ARE DOING THE JOB.
[Re: allmopar]
#1208376
04/02/12 11:29 PM
04/02/12 11:29 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
That is exactly how I do it. Just use a old stock flat top piston. Stock bore piston still works well, even in a .060" over block.
Brian Dunnigan
[Re: '72CudaRacer]
#1208377
04/02/12 11:57 PM
04/02/12 11:57 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought one of these and really like the way it works. My son Matt was using it tonight fitting the rings for his new engine. http://www.summitracing.com/parts/SME-906002/
[Re: jamesc]
#1208380
04/03/12 10:26 AM
04/03/12 10:26 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
apparently you do want a "snug" fit to know the accurate size of the gap. I always used a "smooth" feel. I can drop the feeler gauge in, it doens't wiggle side to side at all, and I can slide it up and down against the cylinder wall, through the gap, and it "glides" through.
when I talked to the tech guy at KB, he told me that my gaps would actually be a bit bigger than what I was measuring because of how I was measuring.
oh well. too big on ring gaps are better than too small. Plus, I think I've seen some write ups from different builders online who say that they've noticed no loss in Hp with as much as a .060" ring gap
**Photobucket sucks**
