Mopar Marine conversion kits #1207303
04/01/12 12:50 AM
04/01/12 12:50 AM
FastOne Offline OP
FastOne  Offline OP
is there a company or anyone else that makes marine conversion kits for either small or big block Mopar?
thanx
Re: Mopar Marine conversion kits [Re: FastOne] #1207304
04/01/12 12:55 AM
04/01/12 12:55 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I don't think anyone sells complete kits. What parts are you looking for? Basically what you need are the water cooled manifolds unless it's something like a drag jet boat. Brass freeze plugs, water pump that's okay for water-only, marine type starter, alternator, carb, distributor. Flywheel, old bell housing or a plate to mount your starter to and the coupler that mounts on your flywheel to accept you drive's input shaft.
Re: Mopar Marine conversion kits [Re: DaytonaTurbo] #1207305
04/01/12 01:25 AM
04/01/12 01:25 AM
FastOne Offline OP
FastOne  Offline OP
ok, water cooled manifold would be a good start to suit LA, I REALLY don't want to go with a Chevy
Re: Mopar Marine conversion kits [Re: FastOne] #1207306
04/01/12 03:13 AM
04/01/12 03:13 AM
FastOne Offline OP
FastOne  Offline OP
Barr Marine
Re: Mopar Marine conversion kits [Re: FastOne] #1207307
04/01/12 05:20 AM
04/01/12 05:20 AM
Manitoba, Canada
Manitoba, Canada
The manifolds are out there. I think they retail between 200-400 bucks a piece depending on brand, retailer, etc.
Re: Mopar Marine conversion kits [Re: DaytonaTurbo] #1207308
04/01/12 06:10 AM
04/01/12 06:10 AM
FastOne Offline OP
FastOne  Offline OP
yep, I'm feeling more confident now, will be interesting to see how a 408 goes on the water, feel sorry for the guy on the Ski's
thanx
Re: Mopar Marine conversion kits [Re: FastOne] #1207309
04/01/12 11:03 AM
04/01/12 11:03 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
You do realize that engine power band and rpm need to be matched to boat load and propeller pitch/diameter?
Re: Mopar Marine conversion kits [Re: FastOne] #1207310
04/01/12 11:34 AM
04/01/12 11:34 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
OSCO Marine in PA..www. osco motors.com..Fax 215-822-5394 ,.1800-7626726I have used them for years ,,they have everything you need ...ask for their catalog..
Re: Mopar Marine conversion kits [Re: dynamite] #1207311
04/01/12 01:01 PM
04/01/12 01:01 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Glenwood Marine has a good selection a BB Chrysler parts for marine use. Aluminum front cover/mount and rear bell/mount will save weight over the OEM Chrysler Marine stuff. Their aluminum exhaust manifolds and risers will cut about 75 lbs of weight over the OEM iron parts.
It's marine parts, expect to pay. OSCO replacement iron manifolds and risers are ~$750, the Glenwood pieces will be ~$1500.
Re: Mopar Marine conversion kits [Re: B5 Bee] #1207312
04/01/12 07:19 PM
04/01/12 07:19 PM
FastOne Offline OP
FastOne  Offline OP
Thanks for all of the info gentlemen, I have a big block here, with alloy manifolds & alloy heads I'd think it will make a pretty good Ski boat
Is anyone running a big block speed boat?
Re: Mopar Marine conversion kits [Re: FastOne] #1207313
11/19/12 06:00 PM
11/19/12 06:00 PM
Leetonia, Ohio
HemiExpress Offline
HemiExpress  Offline
Leetonia, Ohio
I have a complete setup off of a 426 wedge marine motor. Pulled it out of a running boat complete with the Velvet drive. If your interested in it let me know.
