Re: Whats my next step for solving my light-throttle surge? [Re: JohnRR] #1207120
04/02/12 10:21 AM
04/02/12 10:21 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
enlarge the idle feed tube orifice in the primary clusters.
i guess you folks don't understand this, .
He is using a factory stock 440 carb on his 318 , I'd change the step springs before modifying things , but that's me ...
i know, but why would you go after the main metering for an off idle problem?
Re: Whats my next step for solving my light-throttle surge? [Re: Secret Chimp] #1207121
04/02/12 10:35 AM
04/02/12 10:35 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
This is just a shot in the dark, have had it before.
Are you running a vacuum advance? If so, do you have it connected to ported or manifold vacuum source?
I have had manifold vacuum under light or no throttle advance the timing so far it would cause something like your symptoms.
Just a thought.
It takes gasoline to interest me.
Re: Whats my next step for solving my light-throttle surge? [Re: lewtot184] #1207122
04/02/12 10:39 AM
04/02/12 10:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It doesn't sound like an off idle problem to me , but what do I know
