can you use a ball joint press to R and R lca bushings? #1207036
03/31/12 05:01 PM
03/31/12 05:01 PM
Andrewh Offline OP
Andrewh  Offline OP
something like that? rental from parts store.
just wondering if it might work.
65 coronet.
Re: can you use a ball joint press to R and R lca bushings? [Re: Andrewh] #1207037
03/31/12 05:04 PM
03/31/12 05:04 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
I have that tool , never thought to try it , if the screw will fit thru the Tbar end and you weld a washer to the other shell , it should.
Re: can you use a ball joint press to R and R lca bushings? [Re: Andrewh] #1207038
03/31/12 06:13 PM
03/31/12 06:13 PM
Woodbridge NJ
E
ev2mopar Offline
ev2mopar  Offline
E
Woodbridge NJ
I use the kit from Harbor Freight at work. I use it for ball joints, universal joints and yes, control arm bushings.
I made a bunch of adapters out of various sized tubing.
Its not the best tool for the job, but it works well for the frequency that its used.
Re: can you use a ball joint press to R and R lca bushings? [Re: ev2mopar] #1207039
03/31/12 08:24 PM
03/31/12 08:24 PM
Andrewh Offline OP
Andrewh  Offline OP
thanks. thought I might try if I got everything apart today. but as usual the car would not cooperate.
t bar won't move on the passenger side.
can't get a good whack at the pin to move it.
not sure what to do right now. driverside is moving pretty easy. but looks like I won't be ready till tomorrow and if that happens I will pay 10 bucks to a shop to do it.
Re: can you use a ball joint press to R and R lca bushings? [Re: Andrewh] #1207040
03/31/12 10:09 PM
03/31/12 10:09 PM
GMP440 Offline
GMP440  Offline
Yes. I used that very tool to install the lower control arm bushings on my 91' Ford Crown Vic.
Re: can you use a ball joint press to R and R lca bushings? [Re: GMP440] #1207041
04/01/12 12:50 AM
04/01/12 12:50 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
With just the pieces supplied in the kit? no. Alittle ingenuity- it could work.Also, try prying the lower control back using that too push the T-bar out of the frame.then just pull the control arm off the loose bar.pry bar between k-frame and lower control arm pivot. I never remove T-bar alone.
Re: can you use a ball joint press to R and R lca bushings? [Re: moretoys] #1207042
04/01/12 01:02 AM
04/01/12 01:02 AM
Andrewh Offline OP
Andrewh  Offline OP
thanks. started a different thread on the tbar. I tried smacking the lca too. no dice. have to find a bigger pry bar I guess too.
