Mopar Girdle kit #1206587
03/30/12 05:21 PM
03/30/12 05:21 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
Has anyone used one of these Girdle kits?
They claim there ARP Hardware, do ALL ARP hardware have ARP stamped into the studs & nuts?
http://cgi.ebay.com/ebaymotors/ws/eBayIS...984.m1497.l2649
Re: Mopar Girdle kit [Re: Bishop] #1206588
03/30/12 05:36 PM
03/30/12 05:36 PM
Muskegon Mi
dcr Offline
dcr  Offline
Muskegon Mi
Yes I have one in my 512 also noticed that studs were not arp called seller and was told they were made by arp for his application I dont believe that. But he assured me that he has many in use at 900 hp levals with no problems I did use them and as of yet had no problem at about 650 hp but is always in the back of my mind and would like to replaceat some time for peace of mind.Also the the extra studs reccomended for rear main will not work so dont bother with them I guess the studs are prbly better then 40 year old bolts and the quality and fit of girdle makes it a decent bargin.
Re: Mopar Girdle kit [Re: dcr] #1206589
03/30/12 07:40 PM
03/30/12 07:40 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
You will notice that the wording realitive to ARP has been eliminated from the newer ad.
Also, thats a pretty ghetto way of spacing the girdle off the main caps. The picture shows 2 washers, a 12 point nut, another washer on top of the nut, then the girdle. The nuts look like Pro-Comp stuff. The pricing indicates the same.
Re: Mopar Girdle kit [Re: Bishop] #1206590
03/30/12 11:33 PM
03/30/12 11:33 PM
Girdles are a bandaid, not a solution. The only thing they do is provide front to rear stud rigitity(SP, stiffnes to the main fasteners front to rear ) Buy a good set of main caps and real ARP studs and go for it, unless your planning on making more than 700 HP in a stock block and run the dog snott out of it regulary on pump gas, like I do In that case buy a good block
Re: Mopar Girdle kit [Re: Cab_Burge] #1206591
03/30/12 11:46 PM
03/30/12 11:46 PM
Az
Crizila Offline
Crizila  Offline
Az
My machinist pretty much echoed your sentiments. Hope he is right
Fastest 300
Re: Mopar Girdle kit [Re: TrWaters] #1206592
03/31/12 08:50 AM
03/31/12 08:50 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I'm putting an engine together for a friend and he bought the mancicni girdle kit. Nice complete kit but same issue. The long main studs in the kit I am certain are not arp and to make things worse when torquing them down to measure the mains one snapped off. It appeared the hardening process was not right. Mancini said they would replace all the studs with arp but I don't know if they can due to proprietary rights of someone. There have been posts on here about trying to buy these studs direct from arp and they couldn't.
Re: Mopar Girdle kit [Re: mac56] #1206593
04/02/12 02:55 PM
04/02/12 02:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Girdles also do a gret job of captuing the oil right to the front & rear main seals causing leaks. Don't ask us how we know. Found out the hard way. After we clearanced the girdle back away from the counter weights on the front & rear pan seal areas all problems were resolved.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Mopar Girdle kit [Re: 6PKRTSE] #1206594
04/02/12 04:02 PM
04/02/12 04:02 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
We have taken over the bcr product lines and only sell arp hardware in our kits. yes its a little more expensive but well worth the extra insurance when your putting it into your bottom end. we sell girdle kits with caps and just the girdles with hardware. our girdles are 1/2" thick.
Jerry
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Mopar Girdle kit [Re: Cab_Burge] #1206595
04/02/12 04:39 PM
04/02/12 04:39 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Girdles are a bandaid, not a solution...
Yeah, but so are aftermarket main caps, running hard-blok, etc. Some of us can get away w/ a band-aid (or two ), while others are wasting their $$$ to even bother w/ an OEM block due to the power level they make.
Re: Mopar Girdle kit [Re: BradH] #1206596
04/02/12 09:38 PM
04/02/12 09:38 PM
Az
Crizila Offline
Crizila  Offline
Az
Very true . Trying to decide what you can get away with is like trying to hit a moving target while riding a bicycle. Part of the game - how fast can I go with this amount of $. If $ was no object, it wouldn't be that much fun - for me.
Fastest 300
Re: Mopar Girdle kit [Re: mac56] #1206597
04/06/12 10:34 AM
04/06/12 10:34 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Just an update on the mancini kit. Apparently they have had more than just my problem with the studs in their kit. They are trying to get arp studs but may take 5 weeks so they have offered to replace their kit with a hughes engine kit.
Re: Mopar Girdle kit [Re: mac56] #1206598
04/06/12 06:02 PM
04/06/12 06:02 PM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
that girdle kits looks pretty ordinary, 440 source kits are way better, Chenoworth even better again and they both use ARP hardware
