8 3/4 stock axles question
#1206229
03/29/12 09:47 PM
03/29/12 09:47 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I had a customer bring in some 8 3/4 rear end he wants me to swap gears and Sure Grips etc. No problem there. He also brought his axles so I can press on some new Green bearings. All set there. he also brought some Moroso 3" axle studs to install. Problem is, they dont fit. I dont ever do stock axle stuff, so maybe there is an explanation someone can provide. The Moroso stud ( knurl) diamtere is about .680 . The axle holes are about .640 . Is this common, and is there a replacement stud that fits, or will I have to simply bore out the axles? I know its an easy fix, but just looking to see if there is a drop in stud available to save this guy some labor time.To do it right I'd bore them or ream them, so its not just a quick drill.
Sent Dr Diff an email but didnt hear back, so hoping someone here may know. FYI, these axles are off a 65 Coronet, 413 4 speed car. Didnt know if they maybe had two different axles over time. Thanks.
RIP Monte Smith
Re: 8 3/4 stock axles question
[Re: DoctorDiff]
#1206235
04/01/12 02:51 AM
04/01/12 02:51 AM
CompWedgeEngines
Syracuse,NY
Thanks Cass. I ended up just doing that anyhow, a little tight for press fit, but with CMP, it pressed in ok. He already had bought the studs, so I was trying to use what he had instead of making him buy more.
I'll check the email. I went and googled your site, then used the contact info link on there. Cant re-call the address, but I'll pull it back out of email in case something isnt working there.
Thanks.
RIP Monte Smith
