413 RB information??? HELP needed #120606
09/14/08 02:23 PM
09/14/08 02:23 PM
Madison, Wisconsin
chrisnben Offline OP
Madison, Wisconsin
Hey guys- I picked up a super clean 413! It is a RV motor built 4/71. Came complete top to bottom with only 60K miles or so. Air cleaner says 265 HP. Has the HUGE water pump and exhaust manifolds. This engine gets the "most cast iron" award! I am assuming the torque to be around 450-500 FT Lbs.? Can someone give me a website or two for other specs on the industrial/ motorhome engines. The RB pad says GT 413 and a letter "D". The heads are a 2899943 or 948- can't quite tell on the 3 or 8. I have never heard of these castings. Any help would be great!!
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: 413 RB information??? HELP needed [Re: chrisnben] #120607
09/14/08 05:56 PM
09/14/08 05:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
GT 413
G= Year code for 1971
T= Truck
413= Displacement
D= ?
2899 943 is the correct head casting number for the '71-'77 truck 361/413.
Re: 413 RB information??? HELP needed [Re: chrisnben] #120608
09/14/08 06:13 PM
09/14/08 06:13 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
A project that I am working on ... but I plan on USING those 943 heads - with some heavy mods and flow-work. NOT to increase flow but to change to as much as a swirl as possible.
First - those heads are virtually "dead" after 4,000 rpms. But they weren't designed for anything more than that.
What specific info are you looking for?
Re: 413 RB information??? HELP needed [Re: dOc !] #120609
09/14/08 06:32 PM
09/14/08 06:32 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
What do you want to know? Have a '72 413 that's being converted to street use, was going to stroke it, but parts are falling into place to build it as a 6-71 blower motor....
The heads are closed chambers, I had to magnify. the number to read and couldn't find a thing about them, not usable for what I was doing so they sold!
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 413 RB information??? HELP needed [Re: dOc !] #120610
09/14/08 06:34 PM
09/14/08 06:34 PM
Madison, Wisconsin
Madison, Wisconsin
well, probally will sell the heads and put on some 906's I have. waiting to see if I can bore this thing .070 so I can use a 4.25 KB piston and still be streetable. Anyone want to buy (cheap) the exhaust manifolds and heads and intake??
Re: 413 RB information??? HELP needed [Re: R70RUNNER] #120611
09/14/08 06:34 PM
09/14/08 06:34 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Chambers....
Bye Bye!!!!!
Re: 413 RB information??? HELP needed [Re: R70RUNNER] #120612
09/14/08 06:37 PM
09/14/08 06:37 PM
Madison, Wisconsin
Madison, Wisconsin
I should just ebay all the stuff. Maybe someone with an RV or toy hauler can use 'em.
Re: 413 RB information??? HELP needed [Re: chrisnben] #120613
09/14/08 06:39 PM
09/14/08 06:39 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
I got $50 for the heads and pump...Glad to get it... The Rockers are useable, the PR's and bolts are not Send them with the heads!
Re: 413 RB information??? HELP needed [Re: chrisnben] #120614
09/14/08 06:41 PM
09/14/08 06:41 PM
Florida STAYcation
Florida STAYcation
That block should go 70 ...EZ.
Define "cheap" !!
Re: 413 RB information??? HELP needed [Re: R70RUNNER] #120615
09/14/08 06:41 PM
09/14/08 06:41 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Yep, ebay, sold my stuff to a guy with a Travco! he was and so was I
Re: 413 RB information??? HELP needed [Re: R70RUNNER] #120616
09/14/08 06:47 PM
09/14/08 06:47 PM
Madison, Wisconsin
Madison, Wisconsin
just told 440 guy $100 for all the stuff (heads, w. pump, intake, flexplate, exhaust mannys. get it gone is my motto.
My motor didn't have a/c though.
Re: 413 RB information??? HELP needed [Re: dOc !] #120617
09/14/08 06:48 PM
09/14/08 06:48 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
"That block should go 70 ...EZ."
Stout blocks, but your hunting 383 standard bore, or 426W STD, Just not much off the shelf. Custom pistons will kill the cost of the build
Re: 413 RB information??? HELP needed [Re: R70RUNNER] #120618
09/14/08 06:51 PM
09/14/08 06:51 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Nice, good deal for both of you! Heck he could have had my stuff, I know he's really into the 413 MH motors as MH motors! Shipping was just plain prohibitive
Re: 413 RB information??? HELP needed [Re: R70RUNNER] #120619
09/14/08 06:52 PM
09/14/08 06:52 PM
Madison, Wisconsin
Madison, Wisconsin
I found Summit carries KB962 hypers ($250)& TRW cast #z366np ($340), both 4.25 bore- should work. I am keeping the block and crank, rods- that's why I bought it.
Re: 413 RB information??? HELP needed [Re: chrisnben] #120620
09/14/08 07:05 PM
09/14/08 07:05 PM
Florida STAYcation
Florida STAYcation
Custom pistons FERR-SURE ain't cheap ... butttt to put MY package together it might have to be an expense I will have to bear.
The last set of NEW flat-top +30 pistons I bought were about 200$. And they MIGHT NOT work with my combo since I need a higher CD and maybe a mild dome. Those 943 heads have a HUGE combustion chamber - even though they are a closed design.
R70 ... I think I might have emailed you about those parts when they were on eBay !!
Re: 413 RB information??? HELP needed [Re: chrisnben] #120621
09/14/08 07:18 PM
09/14/08 07:18 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Make sure they're Mopar, the valve reliefs are not correct on brand F or X.... AndyF has tied just about every way possible to use other brands pistons, with YARD SALE results!
440G.. Yep we talked, and thanks for the infor!
Re: 413 RB information??? HELP needed [Re: dOc !] #120622
09/14/08 07:19 PM
09/14/08 07:19 PM
Chicagoland
chargerron69 Offline
Chicagoland
440-guy, maybe you should change your name to 413 guy
just saying
Ron
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: 413 RB information??? HELP needed [Re: chargerron69] #120623
09/14/08 07:33 PM
09/14/08 07:33 PM
Florida STAYcation
Florida STAYcation
Yeah Ron ...U R right !
I have 3 440's ....and EIGHT 413's ..and I have 4 more coming !! And one of those is going in a Travco .. that has a 440 in it.
