440 stroker using Hemi crank #1205945
03/29/12 06:17 PM
03/29/12 06:17 PM
New Zealand
Ande Offline OP
Ande  Offline OP
New Zealand
Hi all,
I have a fairly unusual engine combination that I am interested in finding out a bit more about.
The engine is not apart but from what I have been told it is a 440 with a customised 426 crank which has a 4" stroke giving 482 ci.
I imagine that someone would have had to build up the crank to give it that stroke?
The rest of the engine is Edelbroke heads and inlet with Crane Gold series Rollar rockers, custom JE forged pistons, Carillo Rods.
The car is a 1966 Chrysler 300 with 18 spline A833, 8 3/4 LSD, TTI headers with dual 3" exhaust
Re: 440 stroker using Hemi crank [Re: Ande] #1205946
03/29/12 07:45 PM
03/29/12 07:45 PM
dogdays Offline
dogdays  Offline
Sounds like a nice motor with which to scare the woolies! If it is old enough it's probably a welded stroker which means the crank throws are welded up on the outside and the rod journals are then ground with a 4" stroke (or whatever stroke). It works out with a 0.060" overbore which is max for that block. The 4" makes me feel like it was done a long time ago. Modern times have produced a slug of cast and forged stroker cranks and those tend to be either 4.15" or 4.25".
R.
You can't go wrong with JE and carillo, either.
Re: 440 stroker using Hemi crank [Re: dogdays] #1205947
03/29/12 08:17 PM
03/29/12 08:17 PM
New Zealand
Ande Offline OP
Ande  Offline OP
New Zealand
That makes sense, from what I know the car was put together in 2005/ 2006. It does sound like a lot of works with the various stroker options around now.
I didnt know that worked out to 0.060" over though.
It goes well though I have a slappy piston (or 2) that are still abit audible when hot, I guess I will hold doing any work to it until it starts loosing compression.
Re: 440 stroker using Hemi crank [Re: Ande] #1205948
03/29/12 10:36 PM
03/29/12 10:36 PM
The four inch stroke cranks where very poplular in the blown alcholol motors in alcholol dragsters back then, 2003 to 2007 It sounds like it has some very good parts, Carillo rods, JE pistons Only one way to tell, pull the pan and look for welding in the rod throw radius BTW, I bought my first six 4.25 stroker cranks from Ohio Crankshaft in 2001 or 2002 Crower, Lunati, Bryant, LA Billet, Winberg, Eagle and a bunch of other crank company where selling forged steel cranks before then
Re: 440 stroker using Hemi crank [Re: Cab_Burge] #1205949
03/29/12 11:07 PM
03/29/12 11:07 PM
New Zealand
Ande Offline OP
Ande  Offline OP
New Zealand
Cheers for that, not quite a blown alki motor but once I figure out some tuning issues (fouling plugs / noisy valve train) its going to to get alot of use even at US$2.20 litre (about $8.30 a US gallon) for premium.
4 speed in a C class Yacht is already abit of a giggle.
I was told it was in the March 2006 Hot Rod mag which are not not easy to come by here in NZ - no doubt I will find one at a swap meet one day
Re: 440 stroker using Hemi crank [Re: Ande] #1205950
03/29/12 11:35 PM
03/29/12 11:35 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Dang! That's a great looking car.
Sheldon
Re: 440 stroker using Hemi crank [Re: RUNCHARGER] #1205951
03/29/12 11:54 PM
03/29/12 11:54 PM
New Zealand
Ande Offline OP
Ande  Offline OP
New Zealand
Thanks for that, I cant claim credit though as it was built by someone else.
Re: 440 stroker using Hemi crank [Re: Ande] #1205952
03/30/12 12:05 AM
03/30/12 12:05 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: 440 stroker using Hemi crank [Re: 1_WILD_RT] #1205953
03/30/12 12:12 AM
03/30/12 12:12 AM
New Zealand
Ande Offline OP
Ande  Offline OP
New Zealand
Cheers,
Unfortunately my Scotish blood is rebelling at the idea of spending $34.00 Including freight for a $6 mag.
Strangely I have no problems spending much more on car parts
Re: 440 stroker using Hemi crank [Re: Ande] #1205954
03/30/12 11:18 AM
03/30/12 11:18 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Cheers,
That's $1.00 at best mag , what makes that seller think it's worth 15 ???
Re: 440 stroker using Hemi crank [Re: JohnRR] #1205955
03/30/12 05:03 PM
03/30/12 05:03 PM
New Zealand
Ande Offline OP
Ande  Offline OP
New Zealand
Looking for mugs like me I guess, I can wait!
Re: 440 stroker using Hemi crank [Re: Ande] #1205956
03/31/12 02:30 AM
03/31/12 02:30 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I thought all cars down under had to be right hand drive.Do you not drive it on the street or is there a year of manufacture that dictates what is okay?
RT
Re: 440 stroker using Hemi crank [Re: RTSrunner] #1205957
03/31/12 02:38 AM
03/31/12 02:38 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Maybe offset ground and used chevy sized rods?
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 440 stroker using Hemi crank [Re: Silver70] #1205958
03/31/12 03:20 AM
03/31/12 03:20 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I think you would still have to weld to get the stroke that far out. If memory serves, 3.915 is tops for an offset ground stock crank with chevy rods.
Re: 440 stroker using Hemi crank [Re: RTSrunner] #1205959
03/31/12 06:25 AM
03/31/12 06:25 AM
New Zealand
Ande Offline OP
Ande  Offline OP
New Zealand
RT
When importing a car from the States we can get LHD dispensation for cars 20 years or older plus 'special interest' or cars that are not made in RHD.
Dealers are even selling brand new Challangers in LHD here (they aint cheap tho)
The Aussies do it tougher though, most cars have to be converted to RHD.
Still freaks the wife out sometimes siting on the wrong side of the car.
Re: 440 stroker using Hemi crank [Re: DaytonaTurbo] #1205960
03/31/12 06:28 AM
03/31/12 06:28 AM
New Zealand
Ande Offline OP
Ande  Offline OP
New Zealand
One day, hopefully NOT soon I will rip it out and find out how it was all put together
