Do mopar horns go bad and how to test? #1205470
03/29/12 12:19 AM
03/29/12 12:19 AM
KS
MoparKansas Offline OP
KS
I have two different sets of horns that would fit on my Challenger and out of the four none work when hooked up to a battery. Are stock mopar horns known for going bad? Is there a different way you should test them? Is there any way to repair them?
Re: Do mopar horns go bad and how to test? [Re: MoparKansas] #1205471
03/29/12 01:39 AM
03/29/12 01:39 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
I always test them by hooking direct to the battery also. I've had to replace a lot of horns on various cars over the years, even fairly late models, so they do go bad.
I even bought a new purple Road Runner horn that won't work. Too bad I didn't try it when I first bought it, I'd had it about 4 years when I finally got around to using it. Kind of late to ask for a refund.
I haven't figured out how to repair them.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Do mopar horns go bad and how to test? [Re: MoparKansas] #1205472
03/29/12 01:44 AM
03/29/12 01:44 AM
NE
bigtail Offline
bigtail  Offline
NE
There was a post on here recently where a guy washed his and got water in them. Long story short, it is very, very easy to take them apart and sand the contacts inside. there is really not that much to them. They are very simple.
This page is made up completely of recycled electrons.
Re: Do mopar horns go bad and how to test? [Re: bigtail] #1205473
03/29/12 11:47 AM
03/29/12 11:47 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Re: Do mopar horns go bad and how to test? [Re: 70440+6bbl] #1205474
03/29/12 07:22 PM
03/29/12 07:22 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Are you sure you have a good ground?
Re: Do mopar horns go bad and how to test? [Re: drew72] #1205475
03/30/12 07:53 AM
03/30/12 07:53 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive found that if you tap them and use direct batt they will usually start to work.Some you also have to adjust the screw on them.Ive also shot some WD 40 into some and then tap on them.Rocky
Chrysler Firepower
Re: Do mopar horns go bad and how to test? [Re: drew72] #1205476
03/30/12 12:05 PM
03/30/12 12:05 PM
KS
KS
I put the screw for the mounting braket on the negative terminal and then a test light to the positive terminal and the light lit up, but no horn. So it was making a connection... I think I'll try some PB blaster and if that doesn't work tear them apart as in the link. Thanks all.
Re: Do mopar horns go bad and how to test? [Re: MoparKansas] #1205477
03/30/12 12:11 PM
03/30/12 12:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Instead of the test light try just using a piece of wire.
Re: Do mopar horns go bad and how to test? [Re: MoparKansas] #1205478
03/30/12 12:51 PM
03/30/12 12:51 PM
and out of the four none work when hooked up to a battery. Is there a different way you should test them?
If it has a small tone adjusting knob on the side turn it slightly back and forth from center
Re: Do mopar horns go bad and how to test? [Re: RapidRobert] #1205479
03/30/12 06:12 PM
03/30/12 06:12 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
That has worked for me before too.
Re: Do mopar horns go bad and how to test? [Re: MoparKansas] #1205480
03/31/12 12:58 PM
03/31/12 12:58 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
The test light did not make a good connection.Use a jumper wire instead.The test light checked for a complete circuit.You did not have battery power at the horn.The horn on ground lug is good.+ connection was not. A fused jumper wire would be best.But any wire will work.Yes you will get a slight arc when connected.don't use phone line thin wire neither.
Re: Do mopar horns go bad and how to test? [Re: Reggie] #1205481
03/31/12 01:05 PM
03/31/12 01:05 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Exactly, if the screw is too loose, or too tight, the horn cant vibrate and no sound. This is one of the more obnoxious things you can do in your garage. Shooting guns is another but I digress.
Re: Do mopar horns go bad and how to test? [Re: Pacnorthcuda] #1205482
04/17/12 04:28 PM
04/17/12 04:28 PM
KS
KS
I got two of them to work with a jumper wire painted them up and put them in last night. I think my problem must've been the test light or poor ground. I wire wheeled the bracket, used the test wire and all was well.
Thanks for all the help - now I'm "horny" lol...
