Getting a 413 Wedge, 1BBL to Breathe Easier? #1204858
03/28/12 01:14 AM
03/28/12 01:14 AM
Philadelphia
TorqueChap Offline OP
Philadelphia
Looking to help my '65 300L breath better as the OEM filter/air cleaner combo is way too small. Any suggestions for an off-the shelf solution that would bolt right on?
Re: Getting a 413 Wedge, 1BBL to Breathe Easier? [Re: TorqueChap] #1204859
03/28/12 01:16 AM
03/28/12 01:16 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
1bbl 413?
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Getting a 413 Wedge, 1BBL to Breathe Easier? [Re: DARTH V8Я] #1204860
03/28/12 01:28 AM
03/28/12 01:28 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Is it possible that you have confused a carburetor description with an air cleaner? If your 413 has a single inlet on the air cleaner, that isn't considered a ONE barrel. Some call it a single snorkel. If this is the case, there is help out there! Measure the diameter of the point at which the steel air cleaner assembly contacts the carburetor. Take that number and go to an auto parts store and ask for an aftermarket open element assembly. If need be, bring the original air cleaner assembly with you.
Re: Getting a 413 Wedge, 1BBL to Breathe Easier? [Re: Kern Dog] #1204861
03/28/12 01:36 AM
03/28/12 01:36 AM
Philadelphia
Philadelphia
Mea culpa for the NooB mistake. Yep, "air cleaner" is the name of the game. The OEM unit is super small and I'd like to give the 413 a chance to take in larger gulps of air.
Re: Getting a 413 Wedge, 1BBL to Breathe Easier? [Re: TorqueChap] #1204862
03/28/12 01:41 AM
03/28/12 01:41 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Do you like CHEAP?
You could simply use a flat lid atop the filter that is in there, in effect making your current assembly into an open element unit. Many guys toss out stock stuff when they switch to aftermarket parts. Maybe a local junkyard has what you need. Look at the trucks. Many of those parts are still on the trucks when they get pulled and crushed.
Re: Getting a 413 Wedge, 1BBL to Breathe Easier? [Re: Kern Dog] #1204863
03/28/12 02:02 AM
03/28/12 02:02 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Do you like CHEAP?
Do you like EVEN cheaper? Just flip the stock lid upside down!
Re: Getting a 413 Wedge, 1BBL to Breathe Easier? [Re: DaytonaTurbo] #1204864
03/28/12 02:53 AM
03/28/12 02:53 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
You must not be too familiar with early mopar air cleaners They would look pretty funny with the lids flipped.
I believe a '65 300L should have this unsilenced air cleaner, does it?
If not, check out Nick's Garage , there may be a dual snorkle top to match your base. Does your car still have the small throat (~4-1/4") diameter AFB? ..... or has the carb been changed?
Nothing about 1965 Chrysler 300L sounds cheap!! Got Pics?
Re: Getting a 413 Wedge, 1BBL to Breathe Easier? [Re: 6bblgt] #1204865
03/28/12 03:01 AM
03/28/12 03:01 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Thats the design that I expected to see. When you remove the "lid", the filter stands wide open from the sides and top. In that scenario, a newer flat lid would be the way to go.
By the way.... WHEN did ma Mopar ditch the inverted air cleaner design for the more common type? Early 70s?
Re: Getting a 413 Wedge, 1BBL to Breathe Easier? [Re: Kern Dog] #1204866
03/28/12 03:05 AM
03/28/12 03:05 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 was the last year for the "flat" style base with a larger "lid".
Re: Getting a 413 Wedge to Breathe Easier? [Re: 6bblgt] #1204867
03/28/12 08:39 AM
03/28/12 08:39 AM
Philadelphia
Philadelphia
Pics attached as the car came off the semi. Needs a good detail... and a dual snorkel. You're right, the OEM config is an unsilenced air cleaner and original carb. Except for an orange pinstripe on the chrome (coming off the car ASAP), the car is original right down to the convertible top. Will check out Nick's garage. Thanks!
