Re: Getting a 413 Wedge, 1BBL to Breathe Easier?
[Re: Kern Dog]
#1204863
03/28/12 02:02 AM
03/28/12 02:02 AM
DaytonaTurbo
Manitoba, Canada
Do you like CHEAP? You could simply use a flat lid atop the filter that is in there, in effect making your current assembly into an open element unit. Many guys toss out stock stuff when they switch to aftermarket parts. Maybe a local junkyard has what you need. Look at the trucks. Many of those parts are still on the trucks when they get pulled and crushed.
Do you like EVEN cheaper? Just flip the stock lid upside down!
[Re: DaytonaTurbo]
#1204864
03/28/12 02:53 AM
03/28/12 02:53 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
You must not be too familiar with early mopar air cleaners They would look pretty funny with the lids flipped.
I believe a '65 300L should have this unsilenced air cleaner, does it?
If not, check out Nick's Garage , there may be a dual snorkle top to match your base. Does your car still have the small throat (~4-1/4") diameter AFB? ..... or has the carb been changed?
Nothing about 1965 Chrysler 300L sounds cheap!! Got Pics?
Re: Getting a 413 Wedge to Breathe Easier?
[Re: 6bblgt]
#1204867
03/28/12 08:39 AM
03/28/12 08:39 AM
Posts: 176 Philadelphia
TorqueChap
Philadelphia
Pics attached as the car came off the semi. Needs a good detail... and a dual snorkel. You're right, the OEM config is an unsilenced air cleaner and original carb. Except for an orange pinstripe on the chrome (coming off the car ASAP), the car is original right down to the convertible top. Will check out Nick's garage. Thanks!
