Wire retainer clips for core support
#1204352
03/27/12 01:01 AM
03/27/12 01:01 AM
Posts: 43,600 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
On my 69 GTS I had all NOS parts welded on the front end including all the core support pieces. The trouble with an NOS core support top bar is that the 5 clips that hold the headlight harness on are not spot welded to the bar and there are arrows that show where they need to go, but I cannot find any new ones. They are thin metal coated with plastic and not easy to remove and do not go back on easily once you try to remove them correctly. Anyone know where to find them new? Here is a pic of a couple of the clips spot welded on the core support bar.
JB Rhinehart, Realist
A-Body's RULE!
Re: Wire retainer clips for core support
[Re: 69 mayflower]
#1204354
03/27/12 10:10 AM
03/27/12 10:10 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Cut some strips of sheetmetal,tack weld them to the core support,coat them with Plasti-dip.Done.
[Re: JohnRR]
#1204355
03/27/12 11:20 AM
03/27/12 11:20 AM
Rhinodart
Rhinotruck
Rhinotruck
It is not as easy as that since the car is already painted. The factory clips have holes in them and the ends are turned under, not really easy to recreate that particular part. This car is a restoration not a hot rod. At this point I am going to have to bond them to the core support and want correct looking pieces, someone out there must know where to get real ones!
A-Body's RULE!
[Re: Rhinodart]
#1204356
03/27/12 11:34 AM
03/27/12 11:34 AM
JohnRR
U.S.S.A.
Sounds like you are going to have to dig out a core support and ruin it to get the tabs off in one piece .
[Re: Rhinodart]
#1204358
03/27/12 02:06 PM
03/27/12 02:06 PM
JohnRR
U.S.S.A.
I tried taking them off a junk core support without much success.
spot weld cutter from the backside ?
[Re: Rhinodart]
#1204360
03/27/12 05:01 PM
03/27/12 05:01 PM
JohnRR
U.S.S.A.
Yep, that is the last thing to try, or I could cut them out still on the crossmember then grind them down...
I really assumed you tried to cut the crossmember away from them and not take them off the crossmember . You pretty much have to wreck the part you are trying to reuse.
