Wire retainer clips for core support #1204352
03/27/12 01:01 AM
03/27/12 01:01 AM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
On my 69 GTS I had all NOS parts welded on the front end including all the core support pieces. The trouble with an NOS core support top bar is that the 5 clips that hold the headlight harness on are not spot welded to the bar and there are arrows that show where they need to go, but I cannot find any new ones. They are thin metal coated with plastic and not easy to remove and do not go back on easily once you try to remove them correctly. Anyone know where to find them new? Here is a pic of a couple of the clips spot welded on the core support bar.
JB Rhinehart, Realist
A-Body's RULE!
Re: Wire retainer clips for core support [Re: Rhinodart] #1204353
03/27/12 03:51 AM
03/27/12 03:51 AM
alaska
69 mayflower Offline
alaska
Cut some strips of sheetmetal,tack weld them to the core support,coat them with Plasti-dip.Done.
1969 Plymouth Sport Satellite 383 1990 Dodge W150 plowtruck 318 2012 Dodge Ram 1500 4WD 5.7 HEMI 2012 Dodge Challenger R/T Classic Blackberry Pearl 5.7 HEMI MOPAR- WHAT ALL OTHER CARS WANT TO BE WHEN THEY GROW UP-
Re: Wire retainer clips for core support [Re: 69 mayflower] #1204354
03/27/12 10:10 AM
03/27/12 10:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Wire retainer clips for core support [Re: JohnRR] #1204355
03/27/12 11:20 AM
03/27/12 11:20 AM
Rhinotruck
Rhinotruck
It is not as easy as that since the car is already painted. The factory clips have holes in them and the ends are turned under, not really easy to recreate that particular part. This car is a restoration not a hot rod. At this point I am going to have to bond them to the core support and want correct looking pieces, someone out there must know where to get real ones!
A-Body's RULE!
Re: Wire retainer clips for core support [Re: Rhinodart] #1204356
03/27/12 11:34 AM
03/27/12 11:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sounds like you are going to have to dig out a core support and ruin it to get the tabs off in one piece .
Re: Wire retainer clips for core support [Re: JohnRR] #1204357
03/27/12 01:42 PM
03/27/12 01:42 PM
Rhinotruck
Rhinotruck
I tried taking them off a junk core support without much success. Too bad I didn't notice this before it was painted, it is going to be enough fun matching the paint and bonding them on as it is.
A-Body's RULE!
Re: Wire retainer clips for core support [Re: Rhinodart] #1204358
03/27/12 02:06 PM
03/27/12 02:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
spot weld cutter from the backside ?
Re: Wire retainer clips for core support [Re: JohnRR] #1204359
03/27/12 04:24 PM
03/27/12 04:24 PM
Rhinotruck
Rhinotruck
Yep, that is the last thing to try, or I could cut them out still on the crossmember then grind them down...
A-Body's RULE!
Re: Wire retainer clips for core support [Re: Rhinodart] #1204360
03/27/12 05:01 PM
03/27/12 05:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I really assumed you tried to cut the crossmember away from them and not take them off the crossmember . You pretty much have to wreck the part you are trying to reuse.
Re: Wire retainer clips for core support [Re: Rhinodart] #1204361
03/27/12 11:07 PM
03/27/12 11:07 PM
Rhinotruck
Rhinotruck
Well I got a couple of them off a rusty crossmember I had laying around by using an air tool, definitely not the way to go but they were junk anyway so at least I can show what they look like.
A-Body's RULE!
