Steering coupler question #1204329
03/27/12 12:50 AM
03/27/12 12:50 AM
southern Idaho
moparcyco Offline OP
southern Idaho
Kinda new over here read through most of the posts goood info.My question for you guys is what do You use for your steering coupler with your upgraded boxes?The box in my challenger is shot and I can stand it no longer.So I shipped mine to firm feel today but forgot to ask Mr. Ross about the coupler.Is there an upgrade?Or is a properly rebuilt stocker ok?This is an ex drag car being built back to a driver that will have excellent handling.Thanks guys
Re: Steering coupler question [Re: moparcyco] #1204330
03/27/12 02:05 AM
03/27/12 02:05 AM
AndyF Offline
AndyF  Offline
Flaming River has u-joints that replace the coupler. The u-joint saves a little space which can be handy around some headers.
Re: Steering coupler question [Re: AndyF] #1204331
03/27/12 03:16 AM
03/27/12 03:16 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Rick Ehrenberg from Mopar Action advises against the U joint coupling because it has no fore/aft slide action. This could result in broken steering column capsules and worn bearings. I've seen and read of people using them anyway with few problems. Rick is like anyone else though. He has his opinions based on what he believes.
There are rebuild kits for the factory couplers. Steer and Gear offers an alternative to the thin steel retainer that seals in the grease: Its a polyurethane boot that fits over the end of the coupler. They are P R I C E Y though..... $28 each! I called to order a few, thinking that they might be $10-$15 each. I only bought 2 !
Re: Steering coupler question [Re: Kern Dog] #1204332
03/27/12 07:32 AM
03/27/12 07:32 AM
IN
ahy Offline
ahy  Offline
IN
I'm running the re-built stocker. Its nice and tight with new
"shoes".
Re: Steering coupler question [Re: Kern Dog] #1204333
03/27/12 09:32 AM
03/27/12 09:32 AM
the house on the left.
cogen80 Offline
cogen80  Offline
were the stock joints used to provide "fore/aft slide action" ? or was it used to make up for the poor tolerances on the assembly line?
Re: Steering coupler question [Re: cogen80] #1204334
03/27/12 10:21 AM
03/27/12 10:21 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Uni-bodies flex and parts move around. If you don't have reinforcements on the uni-body and the steering mount in particular, you're taking a chance putting a solid coupling in there.
Re: Steering coupler question [Re: TC@HP2] #1204335
03/27/12 01:48 PM
03/27/12 01:48 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Especially true with a C-body, or any other car with a removable fromt subframe or rubber-isolated K-member.
Re: Steering coupler question [Re: Fury Fan] #1204336
03/27/12 02:51 PM
03/27/12 02:51 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
i used my oem with new internals.theres no slop,none
Re: Steering coupler question [Re: cuda-sweden] #1204337
03/27/12 03:53 PM
03/27/12 03:53 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Here is the one I bought. Came in a Mopar labeled sealed bag?? http://www.ebay.com/itm/Steering-Coupler...#ht_2161wt_1163
Mopar to the bone!!!
Re: Steering coupler question [Re: 72Swinger] #1204338
03/28/12 12:18 AM
03/28/12 12:18 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Do you have the Mopar part number off the bag your kit came in?
Re: Steering coupler question [Re: Azzkikrcuda] #1204339
03/28/12 12:57 AM
03/28/12 12:57 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
1-04443436AC
Re: Steering coupler question [Re: 72Swinger] #1204340
03/28/12 01:14 AM
03/28/12 01:14 AM
southern Idaho
southern Idaho
Cool looks like the stocker gets the nod here.I have a ton of slop in my steering.I've never had it apart since I have owned the car so I will rebuild the stock one,as the u joint style looks like way more work than I want to do.Thanks everyone
Re: Steering coupler question [Re: Kern Dog] #1204341
03/28/12 12:56 PM
03/28/12 12:56 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
I bought my coupler rebuild kit from Ehrenberg. The "value-added" part of the deal was the detailed instruction sheet that came with the kit.
Believe it or not, it's easy to muck up the coupler installation, so I appreciated the extra help.
Re: Steering coupler question [Re: moparcyco] #1204342
03/30/12 10:45 PM
03/30/12 10:45 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
The factory coupler is a slip joint. Ask D.R. if he'll match the ebay coupler kit price along with the steering box rebuild.
Re: Steering coupler question [Re: TC@HP2] #1204343
04/03/12 01:12 AM
04/03/12 01:12 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Absolutely correct. Not really dangerous, but once you snap the nylon breakaway pin, or trash the upper bearing, you've set yourself up for lots more work and parts-chasing.
Flaming River's setup works fine with their column (only), because it is a close-tolerance collapsible deal with no breakaway pin.
Rick
Re: Steering coupler question [Re: moparcyco] #1204344
04/03/12 08:47 AM
04/03/12 08:47 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Check to make sure the shoe's are installed properly, if there 90 degrees out you will have lot's of slop. DAMHIK
Re: Steering coupler question [Re: Challenger 1] #1204345
04/04/12 02:02 AM
04/04/12 02:02 AM
southern Idaho
southern Idaho
Thanks for the input, its at least 90 percent the box there could be some slop due to a worn coupler.That was the idea when I posted this.Must be a pretty good design from the factory if that what most guys over here are using,always looking for an upgrade,especially when its coming apart anyways.As always thanks to all my moparts friends
Re: Steering coupler question [Re: moparcyco] #1204346
04/26/12 04:12 PM
04/26/12 04:12 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I really can't bring myself to waste any more time on another factory coupler. Is there any way to improve on the flaming river design? I do plan to use a sector support and frame ties.
Re: Steering coupler question [Re: Montclaire] #1204347
04/26/12 08:50 PM
04/26/12 08:50 PM
michigan,usa
W
woody02 Offline
woody02  Offline
W
michigan,usa
hey killerbee...i have a chally as well with the same sloppy gearbox. what was the cost to send it out and rebuild?also is it being built to stock specs,or are they giving it a firmfeel upgrade? thanks
Re: Steering coupler question [Re: Challenger 1] #1204348
04/26/12 10:59 PM
04/26/12 10:59 PM
PA USA
flatiron Offline
flatiron  Offline
PA USA
Got my stock coupling rebuild kit through Dorman or Napa for like 7 bucks at the local autoparts shop
