Re: Steering coupler question
[Re: Kern Dog]
#1204333
03/27/12 09:32 AM
03/27/12 09:32 AM
Posts: 5,337 the house on the left.
cogen80
advises against the U joint coupling because it has no fore/aft slide action.
were the stock joints used to provide "fore/aft slide action" ? or was it used to make up for the poor tolerances on the assembly line?
[Re: TC@HP2]
#1204343
04/03/12 01:12 AM
04/03/12 01:12 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Uni-bodies flex and parts move around. If you don't have reinforcements on the uni-body and the steering mount in particular, you're taking a chance putting a solid coupling in there.
Absolutely correct. Not really dangerous, but once you snap the nylon breakaway pin, or trash the upper bearing, you've set yourself up for lots more work and parts-chasing.
Flaming River's setup works fine with their column (only), because it is a close-tolerance collapsible deal with no breakaway pin.
Rick
[Re: moparcyco]
#1204344
04/03/12 08:47 AM
04/03/12 08:47 AM
Challenger 1
Cincinnati, Ohio
Cool looks like the stocker gets the nod here.I have a ton of slop in my steering.I've never had it apart since I have owned the car so I will rebuild the stock one,as the u joint style looks like way more work than I want to do.Thanks everyone
Check to make sure the shoe's are installed properly, if there 90 degrees out you will have lot's of slop. DAMHIK
[Re: moparcyco]
#1204346
04/26/12 04:12 PM
04/26/12 04:12 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I really can't bring myself to waste any more time on another factory coupler. Is there any way to improve on the flaming river design? I do plan to use a sector support and frame ties.
[Re: Challenger 1]
#1204348
04/26/12 10:59 PM
04/26/12 10:59 PM
Posts: 724 PA USA
flatiron
PA USA
Got my stock coupling rebuild kit through Dorman or Napa for like 7 bucks at the local autoparts shop
