Re: Help setting up a used 8 3/4" gear pattern
[Re: dizuster]
#1204222
03/26/12 10:48 PM
03/26/12 10:48 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
More pinion shims to move it back into the teeth, then adjust lash and contact pattern?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: dizuster]
#1204225
03/27/12 08:51 PM
03/27/12 08:51 PM
Posts: 5,080 organ
maximum entropy
organ
looks like inadequate pinion depth, and too much lash.
[Re: maximum entropy]
#1204227
03/27/12 09:11 PM
03/27/12 09:11 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Inadequate pinion depth meaning it's too deep or not deep enough? From the drive side, my uneducated opinion is that I can't go too much deeper because it'll be in the root of the ring gear tooth? Could you explain why you think that?
[Re: dizuster]
#1204228
03/27/12 10:36 PM
03/27/12 10:36 PM
dizuster
Oakland, MI
Opened up the backlash to .012" Drive side looks better, but coast side looks the same.
From what I understand, if there is a pinion depth problem, shouldn't the patterns be opposite of eachother?
For example, if the drive side is down at the toe and falling into the heel, wouldn't the coast side show that it would be falling away towards the tip?
In this case, both patterns are falling into the root?
#1204231
03/28/12 04:04 PM
03/28/12 04:04 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
See if this dont help some. http://www.drivetrain.com/parts_catalog/...structions.htmlI would take some shim out as to move the pinion towards the front of the car. It should set the drive side deeper and then you will have to set backlash from there to see where the cost pattern comes out. Good luck , Ron
[Re: Skeptic]
#1204233
03/29/12 07:13 PM
03/29/12 07:13 PM
Posts: 554 Kentucky
clovis
Kentucky
Used gears usually set up better between .008"-.010" backlash. Also for used gears concentrate on the coast side. Trying to chase it from the drive side can become extremely frustrating-just went through this with my Dana. http://www.ringpinion.com/Content/HowTo/...nstructions.pdf
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
