Where did you hide/ mount your orange box? #1204079
03/26/12 08:26 PM
03/26/12 08:26 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, looking for a good place to mount the orange box on a bb 70 coronet. Where did you guys mount yours? Would like to hide it. But not a big deal if I can't. Thanks
Re: Where did you hide/ mount your orange box? [Re: 70VcodeCoronetRT] #1204080
03/26/12 08:28 PM
03/26/12 08:28 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
under the battery tray
Re: Where did you hide/ mount your orange box? [Re: 70VcodeCoronetRT] #1204081
03/26/12 08:43 PM
03/26/12 08:43 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Behind the intake.
Re: Where did you hide/ mount your orange box? [Re: JohnRR] #1204082
03/26/12 08:47 PM
03/26/12 08:47 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Re: Where did you hide/ mount your orange box? [Re: Dougsmopars] #1204083
03/26/12 08:48 PM
03/26/12 08:48 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Behind the intake.
I did as well...
1MYTGTX
Re: Where did you hide/ mount your orange box? [Re: 70VcodeCoronetRT] #1204084
03/26/12 08:49 PM
03/26/12 08:49 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Core support,under the horn.
Re: Where did you hide/ mount your orange box? [Re: 70VcodeCoronetRT] #1204085
03/26/12 09:32 PM
03/26/12 09:32 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
painted it black and put it on front bumper bracket...run the wires right across the rubber fuel line and up to dist [big block] or under battery tray is another good one dan
Re: Where did you hide/ mount your orange box? [Re: pushbutton] #1204086
03/26/12 09:48 PM
03/26/12 09:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I wanted to get it as far away from the heat of the engine and engine compartment so I found a couple of unused firewall plugs at the bulkhead wiring block, ran the wires inside of the wiring harness, then through the bulkhead and mounted the box under the dash on the inside.
If you look at the bulkhead junction block behind that mess of A/C stuff you can just see the red wire. And that's a Holley under the stock unsilenced air filter cover and sitting on top of an Edelbrock aluminum intake with everything (Edelbrock) ground off for "stock appearing"
Re: Where did you hide/ mount your orange box? [Re: A12] #1204087
03/26/12 09:52 PM
03/26/12 09:52 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've heard of them being mounted inside the washer bottle.
Re: Where did you hide/ mount your orange box? [Re: burdar] #1204088
03/26/12 10:49 PM
03/26/12 10:49 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I just don't understand why you resto guys cant just use the stock point distributor to trigger an MSD mounted inside the car somewhere
Gus
64 Plymouth Savoy
Dana 60
Re: Where did you hide/ mount your orange box? [Re: burdar] #1204089
03/26/12 11:07 PM
03/26/12 11:07 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Thats where mines going, shhh!
Re: Where did you hide/ mount your orange box? [Re: NV69B7RR] #1204090
03/26/12 11:17 PM
03/26/12 11:17 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
RIGHT IN BACK OF THE HEADLIGHTS, FRONT OF RAD SUPPORT
Re: Where did you hide/ mount your orange box? [Re: gygeneral] #1204091
03/27/12 12:25 PM
03/27/12 12:25 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
One of the issues for most of us is that if you bought an (expensive) M&H harness you really don't want to start cutting apart the wires. I went with a custom bracket that attached to some of the heater box studs, but the back of the manifold looks like the best idea IMO.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Where did you hide/ mount your orange box? [Re: DPelletier] #1204092
03/27/12 12:39 PM
03/27/12 12:39 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
What I did is have the harness made to accomodate this move. Works great and you don't see it unless you bend down and look.
Re: Where did you hide/ mount your orange box? [Re: gygeneral] #1204093
03/27/12 12:58 PM
03/27/12 12:58 PM
Jackson, Mississippi
CornDogsCharger Offline
I've always done like A12 mentioned. I've mounted them under the dash. It takes a lot of extra work to cut and lengthen the wires and the re-wrap them afterwards to help blend in, but it looks great afterwards. If you didn't notice the extra wire coming from the distributor then you really wouldn't know it had electronic ignition. When I get home I'll post a picture of the bracket I made.
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: Where did you hide/ mount your orange box? [Re: CornDogsCharger] #1204094
03/27/12 02:06 PM
03/27/12 02:06 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
why dont more people run petronix?
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Where did you hide/ mount your orange box? [Re: mopars_1] #1204095
03/27/12 03:08 PM
03/27/12 03:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
M+H Harness supplied harness right out of the box , ran the wiring thru the firewall grommet on the drivers side of the brake booster - box is mounted above on side of the brake pedal bracket.
Re: Where did you hide/ mount your orange box? [Re: gtx6970] #1204096
03/27/12 03:08 PM
03/27/12 03:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
made the bracket to mount it
Re: Where did you hide/ mount your orange box? [Re: fourgearsavoy] #1204097
03/27/12 04:32 PM
03/27/12 04:32 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Gus
And the points will last forever as they dont carry any juice. Also, there is absoluetly NO reason not to run just a standard points distributor on a resto. Properly set up points distributors will give a lifetime of trouble free service especially when you take into account how little these cars get driven on a yearly basis.
MB
Re: Where did you hide/ mount your orange box? [Re: mopars_1] #1204098
03/27/12 04:55 PM
03/27/12 04:55 PM
The Historic Hudson Valley
MONC Offline
MONC  Offline
Why mess with an orange box and where to place it??
