Best 8 3/4 rear would u choice? #1204034
03/26/12 06:44 PM
03/26/12 06:44 PM
Blenheim, Ontario Canada
BlenheimBoy Offline OP
741 casing?
742 casing?
489 casing?
with what gear in a E-body?
Let me know
Thx
Bill
Blenheim-Boy
Re: Best 8 3/4 rear would u choice? [Re: BlenheimBoy] #1204035
03/26/12 06:47 PM
03/26/12 06:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
to do WHAT ??
Re: Best 8 3/4 rear would u choice? [Re: JohnRR] #1204036
03/26/12 06:53 PM
03/26/12 06:53 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
489 housing with a 741/742 clutch style suregrip.
gear ratio depending on use.
I am truckless..
Re: Best 8 3/4 rear would u choice? [Re: JohnRR] #1204037
03/26/12 06:54 PM
03/26/12 06:54 PM
for nice cruisin ride
Re: Best 8 3/4 rear would u choice? [Re: BlenheimBoy] #1204038
03/26/12 08:42 PM
03/26/12 08:42 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Any of them will work just fine and the "weak" thing regarding the 741 that inevitably comes up is BS.
Re: Best 8 3/4 rear would u choice? [Re: BlenheimBoy] #1204039
03/26/12 08:51 PM
03/26/12 08:51 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Thats still too vague. "Nice cruisin ride" to some means they don't really care about acceleration and want semi-decent MPG, other cruisers occasionally 1/4mile the car---BIG difference. Rear tire diameter comes into play also.
...but more often than not, for a street car, the choices usually boil down to a 3.23 or 3.55, MAYBE a 3.73 if you can find it.
Re: Best 8 3/4 rear would u choice? [Re: Pacnorthcuda] #1204040
03/26/12 09:32 PM
03/26/12 09:32 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Off topic a little here, but was a 3.73 ever offered in any 8 3/4 ?
Re: Best 8 3/4 rear would u choice? [Re: Kern Dog] #1204041
03/26/12 09:35 PM
03/26/12 09:35 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
NO aftermarket only for Mopar
stock ratio available for GM products
I am truckless..
Re: Best 8 3/4 rear would u choice? [Re: BlenheimBoy] #1204042
03/26/12 10:20 PM
03/26/12 10:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
742 case, it's the strongest and a 3.23 gear ratio with a Dana clutch type posi, if you want to hot rod the motor now and then You don't want the one legger burn outs when showing off
Re: Best 8 3/4 rear would u choice? [Re: Cab_Burge] #1204043
03/26/12 11:30 PM
03/26/12 11:30 PM
Thx guys
Would 3.55 gears be to tall, maybe running 255, 265 60 15 rear tires?
And be comfortable on street cruise.
Thx
Bill
Re: Best 8 3/4 rear would u choice? [Re: 340SHORTY] #1204044
03/26/12 11:44 PM
03/26/12 11:44 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
With the shim-adjusted spacer conversion replacing the crush sleeve.
Ride eternal, shiny and chrome
Re: Best 8 3/4 rear would u choice? [Re: BlenheimBoy] #1204045
03/27/12 12:07 AM
03/27/12 12:07 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
3.55 is an all around good gear. It will accelerate fine but be liveable on the freeway (er, at ~60-65 anyway).
Re: Best 8 3/4 rear would u choice? [Re: 340SHORTY] #1204046
03/27/12 01:45 AM
03/27/12 01:45 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
3.73 gears were available in late '50s Dodge 8 3/4" pickup rearends.
Re: Best 8 3/4 rear would u choice? [Re: 340SHORTY] #1204047
03/27/12 10:07 AM
03/27/12 10:07 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Shorty an FYI , 741's made after the 68 model year had cone types just like the 489 .
Re: Best 8 3/4 rear would u choice? [Re: JohnRR] #1204048
03/28/12 03:53 AM
03/28/12 03:53 AM
Here
Here
Actually, anything worked on and set up by DrDiff
Re: Best 8 3/4 rear would u choice? [Re: DirectSubjection] #1204049
03/28/12 11:56 AM
03/28/12 11:56 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Exactly what Directsubjection said about Doctor Diff !!!! . . . . but really, you have to look at the gear selection as part of your overall pacakage - your cam (depending on 4speed or auto), your converter (if auto), tire size, and exactly what you want . . . drag racer, cruiser, etc . . .
Seems everyone gets into issues when they figure they can change one part and not have that affect the others . . .
Just my two cents . . .
Cheers
Mark
Re: Best 8 3/4 rear would u choice? [Re: a12rag] #1204050
03/28/12 04:30 PM
03/28/12 04:30 PM
Salem, OH (Quaker City Raceway...
GuruRanger Offline
GuruRanger  Offline
I've used suregrip 3.23 ('68 Road Runner, auto), 3.55 ('73 Road Runner, auto), and 3.91 ('70 Super Bee, 4 speed), and have liked them all for street cars. The 3.91s were a bit steep when I drove it from NE Ohio to Carlisle, but the big L-60-14 Mickey Thompson's helped. If you're going to drive the car alot on the highway and longer trips, I'd go with 3.23's. If you're just driving around town or short trips, then the 3.55's or 3.91's would be fine. Just my opinion. Mine always had the 489 case.
Re: Best 8 3/4 rear would u choice? [Re: GuruRanger] #1204051
03/28/12 04:41 PM
03/28/12 04:41 PM
Iowa, US
oldsklharo Offline
oldsklharo  Offline
Iowa, US
I currently am running a a 489 suregrip case with 3.91 gears and 27" tall tires on my '66 Coronet. At 55mph I am turning 2800 RPM and at 65mph turning 3200. I plan on driving this car to various gatherings and shows around the midwest and want a lower highway cruising RPM along with better MPG so I just recently picked up a 489 open with 3.23's which should get me down to 2150 at 55mph and 2450 at 65mph
Just my
Re: Best 8 3/4 rear would u choice? [Re: BlenheimBoy] #1204052
03/28/12 05:22 PM
03/28/12 05:22 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Real Mopar Men (such as myself, heh) won't settle for less than 4.10s. The high revs at highway speeds don't bother me a bit(great response at any speed). If the motor wears out (doubtful), I'll just rebuild it or plug in a new one !
Re: Best 8 3/4 rear would u choice? [Re: oldsklharo] #1204053
03/28/12 06:36 PM
03/28/12 06:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just my
I would toss a set of 2.76's in it for those long drives .
I
