Re: Exhaust Manifold Treatment
[Re: 4spdana]
#1203200
03/25/12 03:12 PM
03/25/12 03:12 PM
Best cast iron color I have seen is VHT Nu Cast spray.
[Re: 4spdana]
#1203202
03/25/12 05:27 PM
03/25/12 05:27 PM
Posts: 412 Jackson, Mississippi
CornDogsCharger
I am also interested in what many people do for the exhaust manifolds. Most of the time we have either had them coated from Jet-Hot or we have had them powder coated. Both ways have worked well but are not very cost efficient.
As for every other cast iron part, I did it the long drawn out way. After being disappointed with most rattle can cast iron colors, I matched a paint chip card to an actual new cast iron suspension part. Since I work at a body shop, it wasn't that much trouble to do. I mixed up the base coat to match and then topped it off with a satin low gloss clear coat.
Justin "CornDog"
1966 Dodge Charger 1968 Plymouth Satellite (Un-Restored "Survivor") 1969 Dodge Charger (W.B. General Lee) 1969 Dodge Charger (Future DMCL Clone) 1969 Dodge Super Bee, 383 4spd
[Re: ]
#1203205
03/26/12 09:39 AM
03/26/12 09:39 AM
Posts: 6,584 SE Pa.
LimeliteAero
SE Pa.
Brian, Do you have a picture of the VHT paint? Id like to find something in between the two Eastwood choices.
[Re: jkbird59]
#1203208
03/26/12 09:28 PM
03/26/12 09:28 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Blast em clean then have them ceramic coated..Then a final cast grey powdercoat...You wont be dissapointed..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: 72N96RR]
#1203209
03/26/12 09:34 PM
03/26/12 09:34 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Almost everything on that engine above is powdercoated except the hardware, block and heads...
[Re: LimeliteAero]
#1203213
03/27/12 03:18 PM
03/27/12 03:18 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
This is what I used:
http://www.hirschauto.com/prodinfo.asp?number=EMPT-PINT&variation=CST%20IRN%20GR
It is supposed to be one of the best, but do not have the engine in yet to test it.
Ive used Bills engine paints with great results, Which color did you go with and do you have pictures?
I used the cast iron grey. I can take pics when I get home tonight. I bead blasted them, cleaned them with MEK, and then painted them with a cheap foam brush. I can't wait til the car is done so I can see how it holds up!! Supposedly it holds up great, and lasts a long time.
