Exhaust Manifold Treatment #1203199
03/25/12 03:08 PM
03/25/12 03:08 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
eastwood products seem to be the choice for a realistic cast iron look.
should i use the brush on or spray on ?
Re: Exhaust Manifold Treatment [Re: 4spdana] #1203200
03/25/12 03:12 PM
03/25/12 03:12 PM
Best cast iron color I have seen is VHT Nu Cast spray.
Re: Exhaust Manifold Treatment [Re: ] #1203201
03/25/12 04:25 PM
03/25/12 04:25 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
really ? thought everyone here was thinking eastwood.
ok, any others thinking of VHT?
Re: Exhaust Manifold Treatment [Re: 4spdana] #1203202
03/25/12 05:27 PM
03/25/12 05:27 PM
Jackson, Mississippi
CornDogsCharger Offline
I am also interested in what many people do for the exhaust manifolds. Most of the time we have either had them coated from Jet-Hot or we have had them powder coated. Both ways have worked well but are not very cost efficient.
As for every other cast iron part, I did it the long drawn out way. After being disappointed with most rattle can cast iron colors, I matched a paint chip card to an actual new cast iron suspension part. Since I work at a body shop, it wasn't that much trouble to do. I mixed up the base coat to match and then topped it off with a satin low gloss clear coat.
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: Exhaust Manifold Treatment [Re: 4spdana] #1203203
03/25/12 08:00 PM
03/25/12 08:00 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Obviously the OE resto is'nt using anything like the coatings being discussed here... But on that note if you're going the painted route Eastwood is always a good choice for the coating...Holds up well and can be retouched any time the need arises....Get the brush-on and use a foam brush...That gives the best coverage...The spray works well but takes too much to be cost effective on a complete manifold/header job......
Have'nt used the VHT Nu-cast {cast iron} coating yet but have used plenty of the black in the past and it's a good product also...As with any manifold/header application the key is good prep...
Re: Exhaust Manifold Treatment [Re: 4spdana] #1203204
03/25/12 08:32 PM
03/25/12 08:32 PM
CT
1932chrysler Offline
CT
I have used eastwood use foam pad for good coverage follow directions for drying time and recoat with spray gun this makes the metalic in the coating look nice and even
excellent results
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: Exhaust Manifold Treatment [Re: ] #1203205
03/26/12 09:39 AM
03/26/12 09:39 AM
SE Pa.
LimeliteAero Offline
SE Pa.
Brian,
Do you have a picture of the VHT paint? Id like to find something in between the two Eastwood choices.
Re: Exhaust Manifold Treatment [Re: LimeliteAero] #1203206
03/26/12 10:43 AM
03/26/12 10:43 AM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
Here is the VHT paint. SP998 is the part number: http://www.oreillyauto.com/site/c/detail...7&ppt=C0171
Here is a photo of the finished product that I did recently.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Exhaust Manifold Treatment [Re: 70gtx440dana] #1203207
03/26/12 12:51 PM
03/26/12 12:51 PM
nj
jkbird59 Offline
jkbird59  Offline
nj
I have use this product for in between touch up detailing.
http://www.eastwood.com/calyx-manifold-coating.html
Re: Exhaust Manifold Treatment [Re: jkbird59] #1203208
03/26/12 09:28 PM
03/26/12 09:28 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Blast em clean then have them ceramic coated..Then a final cast grey powdercoat...You wont be dissapointed..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Exhaust Manifold Treatment [Re: 72N96RR] #1203209
03/26/12 09:34 PM
03/26/12 09:34 PM
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Almost everything on that engine above is powdercoated except the hardware, block and heads...
Re: Exhaust Manifold Treatment [Re: 72N96RR] #1203210
03/26/12 09:41 PM
03/26/12 09:41 PM
mpls,MN
dodgedakotaman Offline
mpls,MN
I have used the VHT and it looks good and is easy to find at local parts stores, but after 1 or 2 years it will rust back up again depending on how much you drive.
Re: Exhaust Manifold Treatment [Re: dodgedakotaman] #1203211
03/27/12 10:55 AM
03/27/12 10:55 AM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
This is what I used:
http://www.hirschauto.com/prodinfo.asp?number=EMPT-PINT&variation=CST%20IRN%20GR
It is supposed to be one of the best, but do not have the engine in yet to test it.
Re: Exhaust Manifold Treatment [Re: wkroncke17] #1203212
03/27/12 03:06 PM
03/27/12 03:06 PM
SE Pa.
SE Pa.
Ive used Bills engine paints with great results, Which color did you go with and do you have pictures?
Re: Exhaust Manifold Treatment [Re: LimeliteAero] #1203213
03/27/12 03:18 PM
03/27/12 03:18 PM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
I used the cast iron grey. I can take pics when I get home tonight.
I bead blasted them, cleaned them with MEK, and then painted them with a cheap foam brush.
I can't wait til the car is done so I can see how it holds up!!
Supposedly it holds up great, and lasts a long time.
Re: Exhaust Manifold Treatment [Re: wkroncke17] #1203214
03/30/12 12:05 PM
03/30/12 12:05 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I use the Eastwoods stuff and bake it in a oven. Then install them on the motor BEFOR you paint the mtr . Then paint the mtr getting a fair amt of overspray on the manifolds for a OE look.
