broadcast sheet location ??? #1202656
03/24/12 07:39 PM
03/24/12 07:39 PM
country
hemikev Offline OP
hemikev  Offline OP
country
Can you suggest any other places to locate b-sheet for 66 charger it isnt under front seats or glove box area . ant other areas i mite check ??????
Re: broadcast sheet location ??? [Re: hemikev] #1202657
03/24/12 11:05 PM
03/24/12 11:05 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My car had two. One in very good, unstained condition must have been above the glove box. It was found when the glove box liner was removed. It was neatly folded twice, just like a business letter is folded.
Another in poor but readable condition was on the metal floor, under the rear carpet underlay, in front of the rear bench seat, right side. It was folded diagonally and stained by the tar-like sealer.
The one in good condition had handwriting, "Hurst", "green" (interior color), "FM" (radio), "A/C", and "WoodGR" (probably for wood grain door and quarter panel trim).
Re: broadcast sheet location ??? [Re: hemikev] #1202658
03/24/12 11:09 PM
03/24/12 11:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Taped to the back side / top of the glove box insert.
Under the front bucket seats in the springs
Inside the front seat backs
Under the rear seat bottom
In the rear seat back.
Under the package tray (speaker shelf)
Under the carpet
Re: broadcast sheet location ??? [Re: Alaskan_TA] #1202659
03/24/12 11:24 PM
03/24/12 11:24 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have found them in the headliner and the back of door panels too!
JB Rhinehart, Realist
A-Body's RULE!
Re: broadcast sheet location ??? [Re: Rhinodart] #1202660
03/24/12 11:27 PM
03/24/12 11:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Some have been found inside the original tires too, usually the spare.
The 'parts pickers' at the plant in some cases left them, well, wherever they left them.
Re: broadcast sheet location ??? [Re: Alaskan_TA] #1202661
03/25/12 12:55 AM
03/25/12 12:55 AM
TX
dart683341 Offline
dart683341  Offline
TX
Inside back of rear seat here
Re: broadcast sheet location ??? [Re: dart683341] #1202662
03/25/12 02:09 AM
03/25/12 02:09 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Well I have looked every where except inside the rear seat backs and under the carpet behind the rear seats. Ive heard its not real common to find one in these cars but I have not finished looking..The IBM records card appears to be the way to find out more details on the options..
Sent away for mine friday. $45.00
http://wpchryslermuseum.org/page.aspx?pid=400
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: broadcast sheet location ??? [Re: Alaskan_TA] #1202663
03/25/12 12:02 PM
03/25/12 12:02 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Under the carpet
Some of those locations don't work on a '66 Charger or are hard to access, such as the rear seat backs. Same problem in Barracuda fastbacks.
Re: broadcast sheet location ??? [Re: NicksGarage] #1202664
03/25/12 03:43 PM
03/25/12 03:43 PM
Boston Ma
Hamtramck Offline
Hamtramck  Offline
Boston Ma
I found one under the rt frt door panel in a 69 Charger (hamtramck car).
69 roadrunner conv. 4spd B5/X9
