Mech Fuel pump 383 #1202414
03/24/12 09:49 AM
03/24/12 09:49 AM
upstate NY 12839
TMBOOTS Offline OP
TMBOOTS  Offline OP
upstate NY 12839
I want to replace my mechanical fuel pump with another mechanical one, but got a little confused with so many listed-I don't believe I need a high volume pump as my 383 dart is just a mild + motor (trw flat tops-906 heads-comp 280H cam-RPM performer & edel 650 avs 3/8 fuel line -headers)
street driven with occasional blast thru the gears!!
Any recommendations appreciated.
Appreciate your help!!
Re: Mech Fuel pump 383 [Re: TMBOOTS] #1202415
03/24/12 09:54 AM
03/24/12 09:54 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Std. volume/pressure pump will be fine , hopefully it's rubber internal diaphragm is compatible with the ethanol in today's fuels.
Re: Mech Fuel pump 383 [Re: JohnRR] #1202416
03/24/12 10:36 AM
03/24/12 10:36 AM
upstate NY 12839
TMBOOTS Offline OP
TMBOOTS  Offline OP
upstate NY 12839
It appears that the standard volume pump has a 5/16 permanent inlet fuel fitting though, at least in the 2 on line stores checked. Mine is a 3/8 replacement line
Re: Mech Fuel pump 383 [Re: TMBOOTS] #1202417
03/24/12 11:39 AM
03/24/12 11:39 AM
CHRGR69 Offline
CHRGR69  Offline
I have the same set up as you. I used this pump http://www.summitracing.com/parts/ATX-4845/?rtype=10 and double clamped the inlet side. Works fine
Grandma always said I had "hands of gold"!
