It appears that the standard volume pump has a 5/16 permanent inlet fuel fitting though, at least in the 2 on line stores checked. Mine is a 3/8 replacement line
I have the same set up as you. I used this pump http://www.summitracing.com/parts/ATX-4845/?rtype=10 and double clamped the inlet side. Works fine
Grandma always said I had "hands of gold"!
